Cutting 3/16 steel rod on the cheap
Gary Smyth
I have to cut approximately 300 2 1/4" pieces from 3/16" x 48" cold rolled steel rod. I do not have a plasma cutter or metal shear. Forget pliers. I do have a 14" band saw and various grinding wheels. Realizing I will lose a blade for wood can I do that? I do not want to screw up the saw. Frankly I don't want to bang these out one at a time. As it is I will need to go through 15 rods to make 300. I talked to a local fabricator who does have a shear but his labor cost alone was a bit over $100. That's $100 I can use to buy stuff. Any alternatives for doing it myself? What blade to use? Commercial pins are priced at $1.59 each.
