Re: Strobe
TomD
I have seen it. I don't think it is a myth. But you have the wrong scenario. It isn't that the saw is running full blast, making a lot of noise and someone reaches for the blade. Which actually happens without fluro lights, which is part of why we have Saw Stop. What happens is you turn off the saw, presumably look somewhere else like the switch, then you are planing to change the blade, say. As you look back at the freewheeling saw blade, it for a second or two appears to be still so you go about your work, and whack you get a bad cut. It had spooled down to maybe 100 rpm, or whatever synchronizes, and it was still being driven by a motor that weighed tens or even a hundred pounds, at that speed, still very nasty.
I think the issue is more of a concern when dealing with low speed power, like a lot of machine shop processes. There, cutting may proceed at low rates of speed, and the motors have reduction gearing where the result of an accident can be a lot worse than loosing a finger. The UK standards (first found) address this stuff. They note, as I knew, that the effect can be offset, but I have been in shops, where for economy the only lighting was fluorescent.
http://www.healthandsafetyworksni.gov.uk/health_and_safety_in_engineering_workshops_hsg129.pdf
page 16
Actually. My current lathe came with a task lamp that the sophisticated guy who ran it had filled with a fluorescent twisty bulb. It may be a special one such as bill mentioned, I have never seen a strobe with it. I have mixed lighting in the shop. I see no particular ongoing advantage to fluorescent tubes.
Humility is the way to approach accidents. Of course everyone who gets hurt is an idiot, didn't know what they were doing, or wasn't paying attention. All that really does to help is ensure that if one is in an accident one suffers a simultaneous mental injury.
