ADVERTISE HERE - FREE TRIAL
Shaker Wall Clock - Questions...
Joe in a Cleveland suburb
I have been doing some research in preparation of making the subject clock. I've wanted to make one of these for a long time.
I've researched old FWW magazines, PWW magazines, several of my Shaker furniture books, and many many Google searches. I do not plan to make an exact reproduction, but somewhat close in size.
Then one thing that I have a question about is the clock dial; what do I buy? And what size? I've called some of the places I found on Google that supply clock parts. I can't get a straight answer on what the size of the face is!
For example, the web site will list a Shaker Style Metal clock dial as 7-1/2" overall diameter. To me, that means the dial is 7-1/2" in diameter. But what is the size of the metal plate it is printed on? When I call, I can't get them to tell me the size of the plate!
I called them:
Me: the page says 7-1/2" diameter, what is the size of the metal plate?
Answer: 7-1/2"
Me: that's the diameter of the dial, what is the size of the plate?
Answer: 7-1/2"
Me: but isn't 7-1/2" the diameter size?
Answer: Yes
Me: but it looks like the plate is bigger than the dial in the picture. What is the size of the plate?
Answer: 7-1/2"
Me: Ok, thanks... click
Does anybody know the secret?
Guess I'll just order one (along with a quartz movement) and see what I get.
I've seen lots about printing one on paper - do it yourself. I don't want to that. Want something better.
Suggestions?
Thanks for any advice, suggestions.
This is the one I am going to make (or, my version of anyway). It's Isaac Newton Youngs 1840 clock pictured in a couple of my books:
Re: Shaker Wall Clock - Questions...
roger lance
Joe....I have a metal clock plate from Klockit.....catalog number 26882 which is 7 1/2" square with a dial that is 5 1/2" in diameter.....this is in the Shaker style.....hope this helps.
The Klockit catalog appears to mis-use the term diameter when describing the size of the plate. They actually mean that the plate is X" square when they say that the plate is X" in diameter.
I think you stumbled onto the answer. Buy one and have it in hand before you start. Then you will know what you have and can decide whether to have the frame over lay it by an 1/8" or what ever.
I feel your pain. Forty some years ago a friend and I worked our way through college building kitchen cabinets. The conversation was "How side is the range?" 30" "Is it actually 30"?" 30" So, do we leave a 30" hole? Is the range a little under sized? If its actually 30" then maybe we should leave 30 1/8"? 30" (smiling) They never were. In those days we had to send off in the mail for the "cut sheet".
Bought a new range recently. Had the same conversation again. Nothing has has gotten any better.
In the installation guide (twenty page booklet) which was written in three languages so they could give you a third of the information, the diagram was less than two inches square. The only thing I needed out of the whole book and it was about the size of a postage stamp.
Clearly the people that sell things never actually use their own products.
paul in AZ
A clock repair shop will have the components used for replacing pendulum movements with quartz mechanisms. Chances are they will have info about more than one manufacturer or even have parts salvaged from old clocks on hand.
Give one of them a call to see what they have in stock or have information about.
Dick Coers
This one was built in 1994 at Woodworkers Journal Magazine. The dial is a laminate of some sort, stuck to a piece of 1/4" plywood with foam tape. Battery movement. I didn't build this one, but I did work at Woodworkers Journal years after this one was built. The dial itself measures 11 1/2 tall, 12 3/8 wide. No idea if you can still get the dial from the original source, but I can research the origin in a back issue if you want.
Joseph Mulherin, sr
A few years ago I made 9 clocks for my family and friends. Bought all the works from Klockit and made the
clocks to my design. My wife received a mantle clock from the hospital for her good diligent service of 40yrs
so i measured it and came up with my own designs.
Klockit has all the measurements, movements of various sizes and some good designs....check them out.
Re: 3 Ways
TomD
Probably a lot more.
- Always buy the hardware first. It' a nothing in this case, try making a motorcycle or a bicycle, you are thousands into the project before the first weld is struck, and if you are an amateur you don't know if your work will hold, or your design is right.
Once you have the parts, you can rescale the design as required.
- Original clocks, had hand drawn faces, so if you are good at that kind of thing you can make the dial to fit your clock, though you still need the hands to be the right proportion, and so forth, so you are back to having parts on hand, unless you are making those also.
-Similar deal is to download the popular woodworking PDF clock face and laser print it, You can play this either way, but for the most part you can size it any way you want so you have complete face if not parts freedom.
And so forth.
Paul Blackwell
7 1/2" seems rather small for the wall clock in your picture. I made one several years ago, and my dial is 11" square with a 9 1/2" dial. Don't recall offhand where I got it.
Joseph Mulherin, sr
Klockit has them.
merritts antiques and clock parts
del schisler
i have delt with this place for 50 yrs or so and you can get a answare there , the 71/4' disl that is the time ring , hand is 3 1/8" minuite they come as a match set, been in clocks for yrs, i would guess the dial over all is 1/2" from time ring but call and they can measure for you , get the clock shop as they deal in antiques also the link
http://www.merritts.com/clock_parts/public/default.aspx
Jack Guzman from Maine
I second Merritts
I have bought many clock parts from Merritts. They are knowledgeable and helpful.Clock-it is what the name implies they sell kits. Merritts sells parts to clock builders and repair shops.---Jack
