Re: OT-Computer Keys
Cameron Hood
Okay, if you are brave AND you are going to throw the old keyboard away anyway, you can try this. I have done it several times without harm, but..... Unplug the keyboard and take it to the kitchen sink. Fill the sink up with warm water and dish soap and submerse the keyboard in to soak for a while. Don't be easy on it, flip it, shake it, do whatever to try and get water and soap into every part of the keyboard. A couple of hours soaking should do. Now, rinse it off with warm water--and don't be cheap with the water, use lots as you want the soap to get out of it. Finally, try and get the most water out of the keyboard you can by tilting, shaking, spinning, whatever. When you have done the best you can do, put the keyboard someplace warm were the water will evaporate and leave it there for a week or two. DO NOT PLUG IT IN TOO SOON! Finally, plug it in and see if it works. Your keys will be clean if you end up throwing it away. :-)
I have a mouse drying out right now that I did the same way. In a week, I will see if it will work.
