Re: OT Long Undies?
TomD
I probably bought some of the first Chouinard/Patagonia stuff, back in the early 70s, and it was really cheap at the time. Since he was out front with a lock on the fleece market in the US for a few years, he really had no choice but to dump the girl that brung him and switch from the dirtbag element to yuppies.
I don't really see getting the value out of a technical product like that unless one is doing something appropriately weird. I remember skiing in the MEC Wallace Berry top, and nothing else on top, when it was minus 50C in Algonquin, and so dry you could virtually see sparks (we had Jackrabbit graphite on the skis, so it wouldn't create static) and it was comfortable. I used to do a lot of waterfall ice climbing, and almost anything, weather wise, could blow up, or fall down on you, so technical gear made sense. I'd wear the underwear with goretex over it. Used to work in sales and design for a Goretex company, Back in the early 80s, still have one of the Jackets. But I wouldn't buy any more at this point. There is usually a simpler way that works better, unless you have cray conditions, or need to deal with masses of sweat, or weigh is extremely important.
Today I just wear however many 10 dollar sweats are required for the condition. I am not sure there is any real benefit to cramming something under pants, when you can just slap something in a larger size over them.
Also, and this is a real issue, the plastics are a miserable experience if you ever end up in a fire. Guy I slightly know, is a well known international bow hunter, and he was in a narrow cabin when a guy accidentally doused a fire with a pot of white gas. It is bad enough to get burned, let alone to deal with all the melted crap. Kinda ironic, because he sold all kinds of really high end dense wool products for bowhunters, because most synthetics are too noisy, but his base layer was plastic.
I almost got burned to death on a plane once, but I guess you don't need to worry about surviving that. Not something you ever really see coming. I only mention it because if you have some appliance for heat, that has any possibility of causing a fire, you might want to reconsider plastics. Fact is, once in Ireland, in a sweets shop, I melted some gray flanel trousers onto my leg standing too close to a red hot space heater. So you never know. Natural fibers all the way. Unless you really have a reason.
