Blade guide bearings for Jet 18" BS
paul in AZ
The guide bearings on my Jet 18" bandsaw need replacing.
Options include OEM Jet parts; a local shop that quoted $180 to replace all upper and lower bearings; going to a bearing supply shop to get matching bearings or replacing the entire assembly with something like Carters.
Are the Carter guides worth the extra dollars? Other options to consider?
One feature that is not clear to me is ease of use with thumbscrew vs. Allen wrench adjustments. Any problems adjusting with hex keys?
Re: Blade guide bearings for Jet 18" BS
Carters?
YES!
Put them on my JET 18. Couldn't be happier after 10+ years
Re: Carters?
paul in AZ
Mark:
Is this a direct interchange of the whole assembly or is there some fiddling around needed?
Re: Carters?, How odd????
I had exactly the opposite reaction. I put Carters on my Delta 14" saw with riser. MY reaction was that it was some of the worst spent money ever. I wonder if the design is different between the two saws? I clearly don't understand how mine work or how to adjust them to get Mark's reaction. I wish I did. I find them tedious to adjust and fiddly. I thought they would have set screws/knobs in them that I could tune in with my fingers and then lock. What I got requires the use of an Allen wrench or is it two different Allen wrenches. You loosen them and they flop around, you slide them into place and try to tighten them, but they move around while you turn the wrench. Hateful. And the rollers, especially the ones under the table smash the sawdust again the blade hard enough that you can't get it off with an impact tool (a slight exaggeration). I think I am going to the ceramic guides or back to the cool blocks. I wish I liked them as much as Mark does. I would sell them but I don't know anybody I dislike enough to dump them on. Just my two cents worth.
Whole Deal
Strip the old stuff off the and put the new ones one and adjust.
BTW unless you want noise, adjust them with a "dollar" gap all around so the blade runs free under tension.
roger lance
There is a video on youtube from Carters on adjusting their guides. I cannot get it to link for some unknown reason (fill in the blank). Go to youtube.....enter a search under adjusting Carter bandsaw guides.....35+ minute video....good info. Alex Snodgrass is the presenter.
Curt Stivison
I have a 20" jet band and bought 10 guide bearing on ebay delivered for $15. I'm sure they are not OEM bearing but i have used the saw alot for 6 months and they still work fine.
Curt
Bill Blasic
Bill Blasic
I just put a set of Carters on my 18" Grizzly and the difference is astounding! I was going to buy a new bandsaw but thought for $242 I would give it a shot. I had no trouble installing or adjusting the new guides and like i said it is amazing as I can now cut a straight line. It is a completely different saw!
Sounds like you already have bearings? *LINK*
John in NM
If so, you can buy replacements from VX Bearing. Get sealed rather than sheilded. The numbers should be on the bearing seal/sheild, but if not you can always measure them and find them that way.
Bearings
Re: Bearings
I think he's talking about blade guides not motor or wheel bearings.
Good link though
Re: Bearings
paul in AZ
Yes, these are the guide bearings at the sides and back of the blade. The OEM part has a stack of 3 bearings on each side and a thrust bearing behind. Upper and lower. 14 all told.
The repair shop quoted something like $12 for each bearing [incl. labor to change them]. No doubt that one of the bearing supply houses in Phoenix can beat that price if I do the work myself.
I still think I'll go with Carters. Anyone know of a good price? A couple of places have the same $244 + shipping price.
As to the comment about cutting straight I don't want to start a debate on this but the only times I've had real drift once the guides are properly set up is when the tension was way off; feed rate is too fast; or when the blade is dull or has acquired a 'set'.
Re: Bearings
John in NM
The side guide bearings on mine are 608's, which is one of the most common bearings around - 22mm OD and 8mm bore. Bought in bulk they get as cheap as $0.50 - for 10 or so they might run $2 each. Thrust bearings were similar in price when I bought those (larger bearing though) - I got extras since I expected to have to replace them often, but the sealed ones I bought have lasted well.
If you want to save some bucks, look at replacing the bearings on your factory guides - they are probably sheilded (cheaper) and those don't last well. Sealed will last longer, but not indefinitely in such a dusty spot. You should be able to replace all 14 for under $50.
Re: Bearings
John in NM
My impression is that his saw has factory installed bearing blade guides, as does mine. Usually they use cheaper sheilded bearings and the grease gets replaced by dust in short order, but that situation is easily and cheaply fixed by replacing those bearings rather than the entire guide.
Perhaps I should have said "already have bearing guides" in the title.
Re: Bearings
paul in AZ
Thanks.
There is nothing wrong with the assembly mechanism itself so I'll check into replacing just the bearings.
A call to a lumber yard I use and they quote sealed bearings at $6 each. Maybe I'll pull one of the guide assemblies and take it in to a bearing supply shop to see what they have.
TomD
Mark saying he has them on his identical saw is a strong recommendation. I have them as factory on my Laguna and they suck. Very awkward. Not really sure what is gained over friction bearings anyway, but ball bearings aren't bad, just the Carters.
For those of you that like the Carter Guides
Hyjack.....I have the Carter guides on my Delta bandsaw and I am in the camp of those that appear to not like them. I looked at the Carter website and they appear to sell two versions, one with knurled knobs that allow for tool-less adjustments and one that requires two Allen wrenches. I have the version with the Allen wrenches. I find it to be fiddly and tedious. (Operator Error???)
I am suspicious that the version makes all the difference. Those of you that like the guides, which version do you have?
Re: For those of you that like the Carter Guides
TomD
In addition to that, there was a kludgy attachment to the saw that is very awkward. I wonder how great they are when retroed, but maybe they are better as an OEM, or at least when applied to a saw that is more central, like the delta 14 kind of deal.
What is a bit of a tick off is that they aren't anything special as far as I know. They are just OEM like ball bearing guides. Almost all saws have BB guides in the thrust directions, so all they do is counter lateral moves. The big excitement is that they can be purchased in the after market, so how good are they if they screw up a sweet OEM deal, what does that say about the more difficult bread and butter retro.
paul in AZ
Done!
Having nearly ordered Carters I got to thinking that the only thing they bring to the party aside from a different mount is new bearings. The OEM mount worked fine and I prefer the thumbscrews and not to fiddle with Allen wrenches to adjust clearances. That more than the cost was the swing factor.
A new set of 10 sealed bearings cost me $50 at the local bearing supply house. I re-used the old spacers.
And John, the bearings on my Jet 18" are 35mm OD with a 15mm bore.
Back in action and it works like it should.
Thanks for the feedback.
6202's
John in NM
Same as the thrust bearings on mine - my guide bearings are the smaller ones :D
I bought a bunch of extras when I switched them to sealed the first time, and eventually used most of the extras in making some live centers for my duplicator. Handy size to have around.
