I can buy a stack of bandsaw blades that, according to the hand-made tags, range from 93 1/2" to 95" long. My Jet 14" bandsaw calls for 93 1/2" blades. Do you think the 95" blades might work on this saw?
I probably will buy the stack anyhow...$30 for 24 blades...and at least some will fit. The box for some of them is labeled "Marvel." Evidently that company used to make blades for woodworking, but now makes only steel/metal machinery and blades. Any information on this brand?
Joe, if the 95"ers don't work you may be able to re-sell them. I had a Powermatic band saw that, I think, used 95" blades.
I wonder if you could put an extra set of tires on your band saw to take up the slack ? They'd be pretty hard to get on but then you'd have an extra set of tires if you ever needed them.
If they don't work, buy a silver solder kit and make them shorter. I use silver (hard solder) solder to make up to 3/4" blades. I use a stationary disc sander to scarf the joint. It's easier than you think.
Joe.....a friend recently told me that a local sharpening service also welds bandsaw blades for a very inexpensive price......regrettably, that was right after I threw away a blade that had failed at the weld.....I'd check this out.....you might be in line for a "you suck".
Roger, I never said I was going to buy the parts to make this jig up...just told you people that there was a video showing a guy who did have it and did a blade online to show it worked.
And measure from the table to the center of the top wheel, then take the blade off, and see if it will go 1" higher than that. If it will, then you don't need to do anything but put it on and go.
If those are new blades, surely there would be some good ones, if the tooth configuration is something you need.
Shouldn't be any problem to have a saw sharpening service shorten them if you have a problem. Also any metal working shop that has a metal band saw should be able to cut and reweld them very cheaply. (Almost every metal band saw I have used over the years is equipped with the cutter / welder / anneal and grind attachment built in ~mounted on the side of the welder.) It only takes two to five minutes to properly produce a blade as good as any manufacturer welds!
Getting a saw sharpening service to shorten the blades IS a problem. Many sharpening services will ONLY sharpen, not re-weld. And those that will re-weld make it so costly that you can almost replace the blade for the same cost, especially if you are purchasing blades in bulk as the OP seems to be doing.
To Joe Pack, follow the advice of Keith Newton. With a blade on and properly tensioned measure from top of table to center of upper flywheel. Remove blade, crank it all the way to the highest point upper wheel will go, and measure again. If it is 1" or more then you can use those 95" blades.
BTW, where did you come across this bargain? I would like to make a similar purchase, but I need 145" blades (144.5-148 will work).
Don't know where you live but in my area there is one local sharpening service, they are a full service shop - sharpening band and circular blades with state of the art CNC grinders, and are quite reasonable for both new blades and service of older blades. There are at least 5 tool shops within 25 miles of my home and all are fully capable of making and or modifying band saw blades, from the prices I have paid for work from some of these shops they are very reasonable for minor work like this, especially if you have a quantity of blades to shorten. I was an Engineer for about 40 years in a manufacturing facility and used these shops frequently for work our tool room was too busy to finish.
