Spice Box 5- Profiling the drawer dividers
Shaping the divider front edge
PIC1
As seen in the photo of an earlier made spice box the dividers have a bull nose profile. This profile leads to the necessity of mitering the intersections as previously described, so why the bother? The tiny drawers have flat bottoms so as to not waste space. This decision leads to a problem. How to stop the drawers in some precise predictable position? I don’t have an answer to that question. Do you?
An alternative is to not stop them in some precise predictable position. The drawers can be made a bit shorter than the case depth (which will change with humidity), and let the drawers stop against the back of the case. With a rounded profile on the dividers it is less offensive to the eye for the drawer front to not be precisely positioned relative to the divider front. The drawer fronts wind up more or less where the bull nose transitions to flat and that seems to look ok if it varies a bit.
PIC 2
I like to scrape these bull nose profiles. The slight irregularities in my rendition of a scraped profile catches the light nicely. I needed to make a scraper with about a 3/8” diameter profile. I use a bow saw a lot for trail maintenance and kindling. Sandvick blades are the best, but I seldom see them for sale. I scored a 24” blade and cut it back to fit my 21” saw, leaving the cut-off. Note: Sandvick bow saw blades make dandy scraper stock! Don’t forget to polish the faces or it won’t cut well.
PIC 3
The final picture shows the 72 drawer parts needing to be dovetailed together. More on the later, maybe a LOT later.
