Geometrical confusion: laying out a cut
I'm putting outside casing on a window installation on our Olde Haus. I'll be applying it on top of a slanted sill, but the casing also has to go at an angle vertically; in other words, the cut, seen from the face, will not be 90 degrees, but off by about five degrees, in addition to the slant of the cut seen from the edge. Work is being done on a chopsaw.
I took off the angles with adjustable bevels. Can I tilt the saw, using the bevel setting for the sill tilt; and then adjust the tilted saw to the angle for the face cut? Or will the first tilt throw off the second one?
