bandsaw upgrade: italian, hammer, something else??
Adrian
My 14" Grizzly G0555 saw (with riser block) is getting increasingly frustrating. The guide post is not perpendicular to the table (off by 1/4" or so) so the guides need constant readjustment. A couple days ago I was resawing some 9" wide mahogany and the kreg fence slipped. And I had forgotten to tinker properly with the guides so the blade got forced forward and once I lowered the guide assembly I had a really hard time getting it to come back to center (my wheels are coplanar). It seems like it's time to think seriously about an upgrade.
So I've been looking at the options and trying to read old posts on the forums. I'm mostly a hand tool shop and I do not have a table saw. I use the bandsaw for ripping, for resawing, and occasional curve cutting. I have found over the years that changing the blade is so much trouble it just never happens, so I have a 3/8" 3/4 tpi carbide blade on the saw. I'm thinking that I should look at 16"-18" saws. Note that I have ductwork on the ceiling giving me a height limit of about 78.5".
So in pondering what the new saw should do, I think it must have a brake. I want a quick tension release that can be seen from the front so I can tell if the tension is on. I have never wished for more resaw capacity than I have now, at 12", but I have often wished for more throat depth. So while I wouldn't say no to increased resaw, I'm not sure that it's important. I have to be able to get the saw down the stairs into my basement shop. I saw one saw advertised "geared trunnions", which seems like it would be nice for adjusting the table accurately. Table extensions seems like a great idea. It's hard to tell which saws have which features.
So what saws do I see as options? There's Laguna LT16, Multimaster MM16, Aggazanni (no info on models seems to be available online, B18???), and the Hammer N4400. Have I overlooked anything? The Felder is too tall. It appears that neither the Laguna nor Hammer have a quick tension release.
Can you comment on whether saws have or don't have features I'm looking for? Do you have one of these saws? If so, what is your least favorite thing about it? What about it bugs you?
Will the stock fence be adequate or will I need to plan for a Driftmaster or some other sort of aftermarket fence? It seems like each saw has its own different guide system, and I'm not sure how much of a difference this really makes.
