Veritas - Innovation in Tools
staining A&C style chair
mildbill
Now that I have the filtration system on our Koi pond close to complete, if there's any money left, I want to get back in the shop. I started an Arts & Crafts style chair some time ago to match the bed I made. I have a question about staining the spindles. I was wondering if it is necessary to stain the spindles before putting it together or can I just wait until it is assembled to stain. To save time I would like to do it after it is complete but if it will take away from the quality of the project I will take the extra time to disassemble and stain everything individually.
Thanks
Re: staining A&C style chair
No suggestions?
roger lance
IMHO, I'd suggest finishing the individual parts of your A&C project before assembly. I've learned this the hard way.....especially if there are a lot of spindles involved.....the resulting project will look better and your sanity may stay intact.
I've done my share of A&C spindle-style pieces:
"Prairie" couch
Deacon's Bench
All spindles were prefinished, including the stain, sealer, and top-coat, before assembly. The tenons were drilled with a 1/8" bit, then wrapped in masking tape. The spindles were then set up with each set on a pin board made with brads so the entire piece was easy to reach to get even tone and finish. When done, the tape was removed and the pieces were glued into the assemblies.
Note: The mating rails and other parts were also prefinished as it wound be near impossible to get good work done and not screw up the prefinished parts with the spindles glued in place.
Jim in Burlington Ont.
Jim in River Oaks, Ont.
I too have done this, pre-staining was a great advantage. I used masking tape on glue surfaces. I also used a 4 step hand process for staining as defined by Jeff Jewitt.
Take care,
Jim
Jesse Cloud
I always refinish chair parts. Its delayed gratification, but in the end I think it saves a lot of work and reduces the risk of a finishing train wreck.
