Improving my grip,
Improving my grip,
Improving my grip,
Keith Newton
After about half an hour of running 6x6x8' post over the jointer, spitting on my fingers to improve my grip, and only 1/3 of the way through this job, I stopped to search for a solution.
I ended up putting an old cotton sock in a plastic dip container, with water. There is plenty of room behind the fence to set it within easy reach. Now it should be more sanitary to shake hands with someone, should they walk in. I was wondering if any of you had something that you do, or if there was anything besides water that might improve this.
While it was at that, I sprayed the concrete floor with a light coat of spray contact to improve my footing. This is after all the tool which bit the end of my thumb off a couple of years ago.
Re: Improving my grip,
Not up to the scale of your work.....
roger lance
but I've made an aid that has worked well for me at the jointer by adding sand paper to the bottom of the tool. Great increase in control.....
perhaps you can make something with sand paper to match your large work pieces.
Dick Coers
Rubber bottom push blocks, or rubber coated gloves. The gloves with rubber just on the palm side, knit on the back.
Paulsv
I really don't like gloves around power tools. A blade or bit can snag the glove and pull your hand into the blade or bit.
Keith Newton
Thanks, I had looked around the shop for some of those gloves, but I think my last pair became dog chews. However, while I was out on my bike for lunch, I rode over to the hardware store for another pair. I'll see if I like them better than moist hands.
Dick Coers
I don't get my hands within 6 to 8" of a jointer head. You would have to use a jointer incorrectly, plus be in a world of hurt, if you got your hands that closely to the head. The gloves I am talking about, fit very closely to the hands. Nothing loose on them. I guess the only place I would not use these gloves would be around the drill press. Everywhere else, my hands don't get that close. Your "mileage" may vary.
I vote for Roger's solution
A good old wooden push pad is a positive way to push stuff across the jointer, and a sandpaper strip aids friction. I've tried those fancy, complicated push blocks with all the adjustments and the rubberized surfaces (what're they called?) and I never felt that I could trust the friction coefficent, especially on the jointer, where I was usually flattening rough-sawn wood. I know my old pal Frank Klausz used to have rubber-foam push pads at his jointer, but I was never able to feel comfortable using them. Your mileage may vary.
The bookeepers at work used to have a little tub of something that they would rub their fingers in from time to time, to help them shuffle through papers. Kind of like this stuff: http://www.officedepot.com/a/products/458547/Lee-Sortkwik-50percent-Recycled-Hygienic-Fingertip/. Some of them preferred various versions of rubber fingertips, like http://www.officedepot.com/a/products/964486/Swingline-Rubber-Fingertips-12-1116-Diameter/. I've never tried either of these products in the shop, but the bookkeepers swore by them.
Re: I vote for Roger's solution
Keith Newton
I already have that for smaller parts, but with something this large, I don't know how I could manage to hold something else.
The pair of gloves I bought are great. I've had others before, but these things are so sticky, that if I had something like them for my feet, I might be able to climb a glass wall like the frogs that the kids and I catch and put in the aquarium at the cabin. ha
They are Kinco, Frost Breaker #1788. The rubber grip is a raised crinkle pattern.
I usually just rest the push block on the piece and push by hand until I get to the point where I can grab the block and finish the pass.
Tom Pilsbury (Chicago)
Here's what I use to keep my hands as far away from the blade as possible. I'm not sure where I found the plan for this. Maybe Wood Magazine or The Woodsmith Shop website. I feel a lot safer than when I used plain old push pads.
question about technique with those hook sticks
Dick Coers
I've always wondered about those push sticks with hooks on the back for jointers. I was always taught that once the board passes over the cutter head, all the pressure goes on the outfeed table, and you ignore the stock still over the infeed. If you go back to the indeed side to apply pressure, you might rock the stock and no longer get a flat surface. How do you guys use that hook and not rock pressure back and forth over the cutter?
Not a problem
Interesting question, Dick. I've not had problems with boards rocking, but I guess that depends on the board. Like you, I keep pressure on the outfeed, but I also keep enough pressure on the infeed to keep it from vibrating. The push block with the hook adds positive forward pressure without relying on friction, which can be squirrely with rubber pads if the pads are dusty or the board is rough or slippery. I hate that feeling that I have to push down harder or else lose my grip on the board.
I can't see how the board would rock. The part that has cleared the cutterhead is already thinner and rests on the plane of the outfeed table. The part that has yet to be jointed is in contact with the infeed table until it gets to the cutterhead. Depending on the density of the wood and the sharpness of your jointer knives, you need pressure fore and aft just to keep it from bouncing and giving you a lousy surface.
I guess we all find the technique that feels best to us and then stick with it.
not how I joint
"taught that once the board passes over the cutter head, all the pressure goes on the outfeed table, "
I am right handed, should that make a difference in the description.....
For edge jointing: My left hand forces the piece down on the outfeed bed and into the fence. My right hand, pushes down on the infeed bed, into the fence and forward to advance the piece. For face flattening the force into the fence is not used. This description is for flat or concave boards. Convex boards involve more complicated forces and teetering and I avoid this situation whenever possible.
What is in my right hand depends. Nothing if I can get a safe grip on the end of the piece to force it forward, a high friction pad if I can't. One of those hooked pads would be nice but I never get around to make one.
Ron in Sterling CT
+1 for Tom's pushstick. That is exactly what I built and have used for years. I keep very light downward pressure on the infeed table side, and keep the piece moving forward. I like the length for holding the piece. I feel like I have more control over the stock.
Ron
Re: not how I joint
Dick Coers
I think the technique is more important when the stock is twisted. For edge joining, once the stock is past the cutter, I use a hand over hand on the outfeed side only. I never return to the in feed side. My face jointing technique is somewhat similar to how an industrial machine, like the strat-o-planer, works. No pressure on the in feed.
Re: not how I joint
I use 2 pads. I have a small one with a handle that has a High friction rubber on the bottom. That one is used in my left hand to hold the board tight against the outfeed table. I have a longer one just like was shown above with sandpaper on it and a hook on the end to push the board through the jointer. If it's a long board I use both on top of the board to push until I can get the longer one hooked on the end.
I usually Wax the bed of my jointer before I start because it sits unused for long periods while I'm doing turning work. So I clean it and wax it before using it.
I just purchased a spiral head cutter. It takes far less forward pressure to push the board now. Wish I had purchased one of those many years ago.
Re: question about technique with those hook stick
Jesse Cloud
The hook sticks are great if you are face jointing thin pieces of wood. When I make plies for laminations, I try to get as much out of a board as I safely can, so that last piece may be 1/8 inch or so thick. No way I would put a finger anywhere near that close to a spinning blade. And if you glue the hook on, there's no problem if you go too far and the blade takes a nip out of it.
But I never saw a reason to put downward pressure on the infeed. As Ellis noted, the hook provides forward pressure.
William Duffield
I've offered advise on this subject here a couple of times over the years. One of these might help.
http://www.woodcentral.com/woodworking/forum/archives_handtools.pl?pro=search;pmd=sread;srchid=5263E11QJp3PjzspSY71414109594;spage=1;sanc=78003;sbid=3105;md=read;id=78003#m_78003
http://www.woodcentral.com/woodworking/forum/messages.pl?pro=search;pmd=sread;srchid=6158yFZgONLDmPSvVb61414109741;spage=1;sanc=482639;sbid=1000;md=read;id=482639#m_482639
Sawing thin strips or veneer from a plank
It is not uncommon for the plank to warp as slices are removed from it, which requires more face flattening, especially in the case of figured wood. The way I solved this and the jointing the last smidgen issue is to glue the piece to be sliced to a backer piece 2" think. No warping and slices can be taken to the last bit of the plank.
