Plywood in mobile base?
How many of y'all ever use plywood in a mobile base?
We ordered the G0715P Hybrid and bought the mobile base.
Should I put a piece of plywood in the mobile base or not? I don't have them in my mobile bases in my own shop, but I have seen recommendations to do so.
Verdict?
Re: Plywood in mobile base?
Why?
John in NM
The only one of mine that has it is the mortiser, more to keep the cuttings away from the wheels than anything else (they can fall right through the center of mine).
But my bases are all made of angle iron and are quite a bit heavier than the ones for sale. If the instructions recommend it I would use it, if not then don't bother.
PS
See no benefit for a cabinet or "quasi" cab saw as the dust will pile up inside the cabinet unless you're using some kind of collector. You do want to adjust your base to closely fit the cabinet's corners so the ply would not be doing anything for the structural integrity of the base.
William Duffield
The only plywood I've used in a mobile base is spacers at the corners, not under the machine, for a base that was a little too large for a bandsaw. They keep the machine from sliding around and dropping off the corner brackets.
Of course, there are some relatively cheap and flimsy mobile bases that are a set of four wheels and brackets that need to be screwed to the corners of a sheet of plywood to make up a base of any size you need. I assume that's not the type of base you are interested in. For example:
http://www.woodcraft.com/Product/152711/WoodRiver-Universal-Mobile-Base-Hardware-Kit.aspx
TomD
Theoretically on heavy machines, the mobile bases are configured so the machine can be inserted in two step, without there ever being a requirement to get a base fully under the machine. With ply, unless you are just dropping in a panel, you would want to be sure what you are planing will not require hoisting the machine, unless you are planing that approach.
Depends on purpose of the ply.....
roger lance
I have a relatively small basement shop with more power tools than space. So, the main tools, which are daily users, have a set place in the shop and the occasional use tools are stored outside the shop and are wheeled in when needed. All of my tools are on mobile bases except the lathe and tools like the table saw and jointer do not have plywood in their bases as their bases were made for that particular tool which fills the area of the base. However, for some tools like the drill press and hollow chisel mortiser, plywood was added to help give stability/mobility to the tool....
and for other tools, ply was added to give a place for storage of other tools or items used to set-up the tool like my radial arm saw and planer.....
So, I'd say it depends on the circumstances of your situation.
