Squeaky Table Saw
Bart Goldberg
My cabinet saw is squeaky when change blade height. I have never lubricated the trunions. What is the prefer way/product to use?
Thanks
Bart
Squeaky Table Saw
Bart Goldberg
Thanks
Bart
Re: Squeaky Table Saw
Pete in Holland MI
Look for a dry spray on graphite lubrication. Anything wet will draw the dust.
Even liberal amounts of graphite powder will help. You need to focus on the lead screws.
Pete
paste wax
This is not my idea but rather the recommendation of the service technician from whom I took a maintenance course many years ago. Scoop up a gob on your fingers and force it into the assembly.
Re: paste wax
Bart Goldberg
Bill,
Have you tried this ? Wouldn't pate wax tend to be sticky?
TopCote/GlideCote
Kneale Brownson
I've used TopCote both on the tablesaw top (and all the other tops) and in the saw workings for years and years. Now it's called GlideCote. Also applied to things like the screws on clamping devices.
Bill Howatt
I've used paraffin wax - the stuff they tend to sell for canning although I'm not sure how many people seal canned stuff with it anymore. Comes in hard bars and I certainly wouldn't classify it as sticky for excessive dust collection. If your rubbing spot is an awkward place the hardness may not make it a good solution.
Bill
Jesse Cloud
And, of course, before you apply any lubricant, use an old toothbrush or such to clean any crud away from the screws. Run them in and out a few times and repeat until they are clean, then lube.
Re: TopCote/GlideCote
Bart Goldberg
While looking up Topcote - I saw that Bostik also make a product called Bearing Lube. It looks like it might be even better for my intended purpose. Anyone here have any experience with this?
I have used Johnson's past wax for 40 years
Would the Delta service technician recommend it if it was not good to use? Paste wax dries to a powder. When you wax your floor or table top is it sticky after drying?
You can use the dry lube sprays and in a week you will be reapplying it. The wax lasts months.
I use bees wax. Rub a block across the trunnion teeth and on the worm screws. Crank the elevator and tilt screws through a couple of full cycles to spread the wax. Works OK on my JET Cab.
Boeshield T9
craigd
I tend to use Boeshield T9 for stuff like this, I'm pretty sure it is paraffin in a solvent carrier, which will wick it into joints or hard to reach places and once the solvent flashes off, you're left with wax. Then again, I'd probably also use aerosol WD40 (mineral oil in solvent), it isn't going to wash wood into the joint and the wood will absorb the excess so there won't be a sticky mess. It isn't much of a lubricate but I've found for things that aren't in constant movement, it works for quite some time.
Ditto: Johnson's with a tooth brush.....
the rod behind the winding handle ??
del schisler
that is where i get my squeek on mine, it stick's thro and rub on a piece in their , that is where i get my squeek check their from the frount of the saw ?
Jerry Gibbs
I had a blade mechanism that was hard to raise. I was amazed what I accomplished by simply blowing out all the sawdust.
Yup, paste wax applied with and old toothbrush....
Howard Acheson
...... has been the recommended lubrication for many years. Working the wax in with the toothbrush will remove any gunk in the teeth and leave a smooth non-squeaking surface. A small squirt of 30 weight machine oil applied to the adjustment shaft bearings will keep them in top shape. Wipe off any excess or drips.
Will Johnson's Paste wax work?
Re: Will Johnson's Paste wax work?
Bart Goldberg
I think Bill already stated earlier that he uses Johnson's Paste wax.
Thanks all for your replies!
Best Regards
Bart
It's what the Delta technician used
roger lance
Bart.....see above; I'm a user of Johnson's for the problem you listed.....but, there was an article in FWW years ago by a tech on lubricating a tablesaw in all its many places.....perhaps someone can reference that article or link to it .
Re: Yup, paste wax applied with and old toothbrush
Bart Goldberg
I took your advice. First vacuumed out the inside, blew out dust with compressed air, then applied Johnson's paste wax with a tooth brush - worked great!
Thanks everyone!
Bart
