Have a question? Ask Woody!
Flattening chain Sawn Slab
don stephan
In a back issue of FWW I remember an article by a west coast actor/part time woodworker who had designed a frame and sled allowing a router to flatten a long slab. An artist stopped by this afternoon wanting to flatten both sides of twelve air dried 40" diameter 5" thick ash disks, so that she can carve designs against the growth ring backgrounds. If there are interesting combinations of heartwood and mineral stains she could have some wonderful "canvasses." Does anyone have a good filing system that can suggest in which issue that article appeared? Thanks in advance.
Re: Flattening chain Sawn Slab
FWW 222, Nick Offerman
Dick Coers
Google is better than my filing system!
Router Planing
I think there was an article on this here on WC; I know it was in Bill Hilton's "Router Magic" and I've used the method on slab stock.
Had some pix of the technique but can't find them.
You set your slab on a flat surface and block up 2 pieces of angle iron as a moveable sled that spans the slab. Space the irons so they hold your router base while allowing the router to slide across the entire slab. You may have to shim the slab to make it stable. Chuck a 1-1/4" planing bit in your router. Place it in the sled and set the depth of the bit to just touch the slab at a point 1/5 of the distance between the highest (thickest) point and the lowest point. Not take router passes across the slab, (right to left) as you advance your sled across the entire piece. Repeat this procedure dropping your router bit a little more each pass. The key here is to take light cuts so your router doesn't ride up and you don't have to press down on the router and angle iron that will bend and produce valleys and/or bumps.
Repeat this operation after resetting the rounter bit for each pass until the bit just barely touches the lowest (thinnest) point.
Flip your slab and repeat the process.
You slab with be dead flat with both surfaces parallel, if needed. If your "bud" is doing a table top and only needs to top surface flat, you can quit after the first side, and let him/her deal with getting the flat side level.
You will, however, likely have slight pass marks about the width of the router bit. You can remove these with careful use of a belt sander, especially if your sander is fitted into a sander frame.
HTH
M
Re: Router Planing
Matt Robinette
Marc the Woodwisperer has a nice video on flattening slabs with the sled ,rails and router method. It is #174
Re: Tag Frid described the system in...
TomD
his books. It is basically like an X-Y gantry system in a CNC machine. But without any of the electronics or drivers. But the FWW article did show a plan. The basic system is simple you lay two boards, or whatever, on either side of the board you want to work, these need to be straight and free of twist. You have a router with a "base" at least twice as wide as the boards are part, it is basically attached to a plank. The vibrating router makes the board slide easily, you just go back and forth across the board with a straight bit taking a light cut, until you have the whole thing cleaned off.
TomD
http://www.finewoodworking.com/workshop/article/router-jig-turns-stumps-into-beautiful-side-tables.aspx
TomD
http://www.youtube.com/watch?v=zIA2Xl8P7Es
Starts around 2:00
Rick L
More important is treatment of the disc...
Rick L
Pentacryl.
http://www.preservation-solutions.com/product/pentacryl/
The router flattening thing is simply intuitive.
hints
Jerry Gibbs
make sure nothing can move- sides of sled if adjustable and bit in collet. take light cuts.
Don, If you are Old School and learned plane basic
Keith Newton
you can save yourself a lot of time using a power-plane as if it were a jointer plane. With my Makita 6" Power-plane, I'll bet I could be through flattening before I could get this router contraption set up to get started.
Even if you aren't that skilled with planing basics, you could probably save yourself a lot of time just using this router contraption to outline , and maybe cut a few cross grooves, then take even a smaller power plane to hog the bulk down to your references.
For hogging off a lot of wood, skewing, or even cutting straight across the grain is a lot easier on the motor and blades than going along the grain. However the long fibers do tend to clog the dust port if you feed too fast.
Keith
I though what he was discribing was flattening END grain of 5" thick "salami slices" from the tree. Planing end grain would be pretty tough to do, no?
Mark, you are right
Keith Newton
Don started his post describing and article that wasn't, which is I guess the only part I remembered after reading the other post. However Ash wouldn't be terrible while green.
The main thing Don needs to point out to his artist friend, is to expect them to check radially. Doing the carving green only requires 1/2 the effort of waiting until it is dry, but will a big old check running through the carving be an enhancement , or a terrible flaw?
What He Said
Don indicated the rounds were "air dried" so I assumed (at my risk) that they are dry and (most likely) already checked to some degree. Carving green is way easier with green wood, but powered burr carving is easier with dry wood as the fibers don't shred and clog the teeth (as much), especially on the end grain.
I still think the router planer is the best way to flatten this stuff unless somebody's got a 48" wide-belt sander and 3 men and a boy to horse the beasties into and out of the machine. :D I could do it on my 22-44 P-Max if it wasn't quite so thick. Since he's talking 5" thickness, after I had made a carrier sled to hold the rounds for the first side "dressing", the thickness would exceed my machine's maximum capacity.
Re: Keith
TomD
Planing end grain isn't bad, but probably not something for someone who may or not even know how to sharpen or set up a plane.
I have used the router thing on turning blocks, possibly the only place I have used it. I made a plywood jig with a circle in it, positioned it with long screws over the end of some very uneven natural edge burl, and then used something like a 3 inch long cutting edge 1/2" straight flute bit to rough out a landing for a face plate. I don't really recall why, but this was the best way to go given I couldn't drill it for a 1" bar, or turn it between centers. Nice thing is the ability to get that face plate at exactly the right horizon to display the natural edge to advantage.
don stephan
Thanks everyone for the great links and tips and suggestions. With two sides of a dozen ash disks the artist can I think easily justify the cost of good a 3HP router, 2 or 3 planer bits, and the frame and sled. The next detail I think will be to meet in her workshop and see where she has room for planing 42" diameter disks.
Don't need 3 hp
I do my slab work with a Dewalt 621 plunger. The wider the workpiece, the longer the bridge translates to the more likelihood of a sag resulting in cutting a "dished" surface. A lighter router will be easier to handle.
John Pappas
https://www.youtube.com/watch?v=zIA2Xl8P7Es
