The construction project is nearing an end. The floor tile went in yesterday and a lot of the wood and trim work went in Friday night and Saturday. Still been doing caulking and painting as well as trying to get many other things finished up. The MIL has moved into her apartment even though I have a few more things to get done for final touches. I don't mind working around her things for the last little bit because she's been waiting since March for a permanent place to call home. This all started in April of this year and is finally drawing to a close. I have determined that I really like working with western cedar and the look and smell of it is wonderful for a nice sun room. My hopes are to have the finishing touches done this week, have all the crown up, caulked and painted as well as the base molding finished. If all goes well, I should be able to have a motorcycle ride for "fun" this coming weekend.
That's it for me, so what did YOU do this past weekend?
All I had time for this weekend ww'g wise was to glue up a couple pieces that will become the top of the Shake Candle stand I am making for my daughter.
I also went to an antique sale yesterday. I wanted to find old tools. I found a lot. Lots of saws, eggbeater drills, and so on. But I think most of the people selling them thought they were worth more than reality... So I passed. I was looking at some decent wooden beading planes for $18, but passed.
I did find one thing though, and bought it! I've always wanted a small oil can. This little thing made my day. 2-5/8" tall.
This year I used my woodworking sharpening skills and equipment to prepare sharp knives for tomato slicing for BLT's and dicing for salsa. If it will pare end grain it will slice a tomato, nicely.
Temporarily, while gathering the parts I needed, I pulled it back together, closing the wound with pipe clamps. I had to move the branches farther than the full extent of the clamps, so after I closed them as far as they would go, I tightened up a loop of rope, adjusted the clamps and retightened them. This took about three iterations.
Then I put a few stainless steel screws through the split, to keep the edges tight together so they would have a chance to seal.
These are the hardware and tools I used to build permanent cables to replace the pipe clamps. The red handled cutters are specifically for cutting stranded cables. The other unusual tool is a Swage-It, which is a press for crimping sleeves onto cables to put loops in the ends of the cables.
There are lots of pages on the net describing how to use this stuff to make rigging for dinghies. Here's one:
I could have used smaller eye bolts, but these are what the Home Depot had in stock. Here are the cables and other parts assembled into a harness. It's all stainless steel. I used the hand screws to hold the Swage-it tool while I inserted the sleeve, threaded the cable through it, wrapped it around a thimble already looped around an eye bolt, threaded it back through the sleeve, pulled everything tight and tightened the nuts to compress the sleeve.
Cables installed, and pipe clamps removed.
We'll know next spring whether it survived the ordeal. I'm very surprised I couldn't find any pictures I had taken of it when it was in bloom last spring. It is Prunus mume "Trumpet."
There's really no need to use fender washers on the backside. It looks like you're using quarter inch screws??? Use the typical diameter. If you use a larger one to get a larger 'footprint' the tree will have more material to grow over and envelope.
Do this...put a regular washer on, against the tree. Then a nut...washer...and second nut.
In time, there will be decay on the inside of the tree where the bolt went through. You can't avoid the decay. The inside washer is seated against the bark, just fine. Don't countersink the washer by cutting away the bark. That just makes a bigger wound. In time, the tree will grow in diameter and envelop the first washer. The decay under that washer may become soft. Depends on a lot of variables. By having the second washer/nut the tree will grow around them and the wood will be solid with no decay.
Next spring you'll start to see callous growing on the edges. Each year they'll grow more...like a lava flow or a Chianti candle. In time, the crack will seal and the cambium will be a continuous sheet again.
I was thinking that the washers were too large. My first thought was to spread out the force, but later realized that the tree would have a lot of difficulty growing over them. I'll find some smaller ones. The eye bolts are 5/16". I would have used 1/4" or even 3/16" but the Home Depot was out of them.
I did get the hall tree done for the Tennessee Parks and Greenways foundation. It was to be auctioned off Saturday at the Sunset on the South Harpeth River event through a silent auction. Weather was bad early in the day but the sky cleared and the event turned out great. The hall tree didn't meet the reserve but it is now at the foundations office where it will be sold at some time in the future. There was talk of the office workers pooling their money and keeping it there. It is all recycled wood the frame and every thing except for the seat top is from a old barn. The seat top is made from a white oak service window surround that I salvaged from a dumpster.
I would have drilled a 1/4" hole, then screwed the 5/16 through, giving it thread bite all the way through. This achieves several things, the first being that it shuts off the air needed to allow decay to start in the drilled hole. Plus, the circumference is almost 1", so multiply that time the length of fiber it locks into.
Then, lets consider your washer area against the smaller one Tom suggested. Under properties in the Encyclopedia of Wood, the crush factor of green Cherry, which is probably the closest species, is 660 psi for green. The area of your fender washer if it was 1" would be .7854", or 518 # of crush resistance. While Toms smaller washer maybe 5/8" has area of .3067 x 660=202 #. Which may be enough if it doesn't bear huge fruit loads, or high storm winds whipping the branches around in different directions, loosening then compressing in a very dynamic way.
Machine threads work great in wood, once you get them started. If it is dry wood in the shop, I may use a tap to get them started, and I'm sure you already have one in your tool kit, but if not, on green wood, I just grind a bit of taper on the end, and push hard on it while getting started. I like to use power to drive fasteners, and one thing I've found for eyes, is to chuck a hook into the drill, then slip the hook into the eye bolt.
When I built my floating boat dock about 8 years ago, which is 18' x 18' on the end of a 20' walkway, I used 5/8" eye bolts into cypress trees, with only the thread bite into the wood, due to the trees being thicker than any bolts I could find, to guy it out. You can imagine how much tension on those fasteners when a big bass boat goes by with some insensitive AH driving, sending off his maximum wake.
