WC Weekend Accomplishments....
Dennis E Peacock
2 Sep 2014
Good Morning Everyone,
Been a VERY busy week for me since we are in the final stages of the construction project. The MIL has started moving in and really looking forward to having her own place to stay and be around caring family. If it all goes well, she should start staying in her own place beginning the end of this week. I still have a lot of caulking and painting to get done and more topsoil to get delivered but we are getting really close. I am hoping to have pics ready to post in the next 2 weeks.
Back to the daily grind today and that's all for me...so what did YOU do this past holiday weekend?
Best of weeks to you all.
Dennis Peacock
Re: WC Weekend Accomplishments....
roger lance
nothing that was woodworking based.....not even a shop improvement.....but I did make my first run of reloaded shells which I'll take to the range tomorrow evening.
Doug Reynolds
Milled many board feet of figured cherry for a class at Marc Adams School of Woodworking. It's a curved front writing desk.
Jerry Roberts
I finally replaced the handles on two very old Chicago Cutlery kitchen knives. Some rivets were gone and the wood was very loose. I replaced one with walnut and the other with some kind of dark wood. I saw somewhere where one used epoxy instead of rivits so that's what I used. Finished one with shellac and the other with polyurethane so Ill see which one outlasts the other. Had to do a lot of power sanding but they did turn out pretty good. Wife was pleased anyway.
Larry Barrett
Completed a couple of carved boxes - black oak.
Re:question for Larry Barrett
Rick Snyder
Hello Larry,
I wanted to comment on your boxes, they really look GREAT! I also noticed the hinges for the boxes and I'm curious as to where you got those hinges. I saw the same hinges on antique box I replicated for a church auction and I would like use them the next time.
Thanks, Rick
Re:question for Larry Barrett *LINK*
Larry Barrett
Hi Rick
Thanks for the compliment. The more authentic snipe hinges are made of wrought iron. Not having any handy, I used brass cotter pins that I found at McMster Carr. The ones I used are 1/8 x 1 1/2.
Brass Cotter Pins
I guess we had the same inspiration
Paul in NJ
Red oak with white pine top and bottom, pintle hinges. A little transtint dye and shellac for the finish.
Paul Dzioba
Joe Bradshaw
Re: I guess we had the same inspiration
Joe Bradshaw
I spent the last with with my 13 yo grandson. I put him on the plane yesterday morning to return to Seattle. He wore me out, but it was great fun. I taught him how to use the ZTR mower. Next year, the FEL.
Joe
Larry Barrett
Hi Paul
Yes indeed, we did have the same inspiration. I have admired Peter's work for some time and have copied a number of things. I have not had the chance to meet him or take a class, but would sure like to.
I like your box. It looks very nice. I didn't stain mine, just used walnut oil. Adding a little tint to the shellac helps to darken red oak, which is a plus. I'll have to try that. It is a real coincidence that we used the same 'rainbow and xmas tree' design. I have made a number of these boxes, some larger, some smaller, and used this design of partrs, of it quite a bit.
Since I'm retired now, weekends have seven days
...although "retired" is a word with complex meanings. Sure not out to pasture.
It was time to repaint the porch on our Victorian house, but first I had to replace some boards that had some end rot. Properly built porches on Victorian houses pitch slightly away from the house, and the tongue-and-groove boards run from the house out to the edge, so that rainwater will drain. This leaves the end grain of every board exposed to the weather.
The boards were in three groups. I started with ripping two "slots" in the board in each group that, once removed, would expose the tongue of the next board in the group:
Once that was done, I jigsawed across and removed the strip I'd cut. More jigsaw work, lots of fussing with chisel, hammer, and nail-removing nippers pulled the first board out. The rest of the boards in each group were simple: cut the board between joists (jigsaw again), knock off the remaining bit on the joist with the hammer and chisel, and pull the nail. New boards were treated on the outer ends with preservative, and bottom-and-end-primed. Once I had the old boards out, I installed the boards conventionally, fitting the grooved side of the board over the tongue on its neighbor and nailing at 45 degrees through the tongue. The last board had to be slid into place from the end, using a certain amount of persuasion. The boards were left a few inches long, so I could trim them in place. Then I face-nailed the last board close to the tongue side, at an angle, filling the holes with Fixall. Success!
It's painted now (sorry, no pics of that yet), and I'm hoping not to have to do this again while we own the house. I do have one board, running under a porch post, with some rot that I'm going to have to inject with some fungicidal preservative; I have no desire to lift up that post (and the roof resting on it)!
