Have a question? Ask Woody!
Basic carpentry set up to build a 12x20 garage?
Charles Jackson III
I am wondering do I have enough tools to build my 12x20 garage I have and Occindental Leather Tool Belt, with the basic carpentry hand tools Sawson speed square, Johnson framing square, Stanley utility knife, Tajima Chalk Box, Dalluge 21 oz framer and a Dalluge 16oz trim hammer, Sands 24'' and 48'' levels, Vintage 26'' Nicholson crosscut handsaw, and a Robert Larson coping saw.
Basic power tool kit I have a Skil 5825 6-1/2'' wormdrive circular saw, Makita LS1020 10'' Miter Saw, and Bosch DDS181-02 18 volt LI cordless drill.
Re: Basic carpentry set up to build a 12x20 garage?
andrew nistock
in my opinion all you "need" is a ruler or tape measure, framing square, handsaw, chalkline, hammer, level and oh yes, lumber. We are much too used to all the "must haves" but just think what our forefathers used. Good luck. Andy
Charles Jackson III
I thought I had more than enough, I don't wont to add more tools that will not get used.
add ladders and a helper
A longer level would be useful but not essential. And saw horses and a quality tape measure. (and a crow bar for pulling nails out that happen to be in the wrong places :)
Re: add ladders and a helper
Charles Jackson III
Going to get me a 8' step ladder and a 16' extension ladder.
They didn't have that many tools....
Dick Coers
to build the pyramids. But they did have a lot of "friends".
Re: Larry Haun videos
TomD
As per here:
https://www.youtube.com/watch?v=9-mS76qjI0g
Good framing hammer and get the right nails, of good quality, no more or less than you local code requires.
If you are roofing, I would buy a roofing nailer, I think it is well worth it and pays for itself on the first job. I got this Craftex one in Canada, and it has been great despite, dropping it from 3 stories onto concrete. It cost about 150 with enough coils to last me a half dozen roofs of the type you are making. Maybe this one would work in your part of the world:
http://www.harborfreight.com/11-gauge-industrial-roofing-nailer-67450.html
One thing to think about is that the normal method of raising walls is to lay them out on the flat nail them on the flat, then raise them. Even better, nail on the sheathing, and a bunch of other stuff like siding often gets added, right up to virtually complete assemblies. Great. However, it used to be done differently. They used to raise a few studs, and then nail the components together in the vertical final position. To do this you can through nail the tops into the studs, and toenail the studs at the bottom. Just keep adding parts till the wall is done. No raising, that if you even have the friends to do it, can be dangerous if they do not know what they are doing. Of course the now conventional method of raising is faster if you can do it.
I would consider a shorter step ladder. Maybe a 6' on. Especially if the ceiling height is eight feet. I just got an eight foot ladder and it won't open under an eight foot ceiling. And if the ladder is close to the the ceiling height, its difficult to move around.
Many years ago I used to frame houses regularly. I knew I could frame a 16' wall and raise it by my self. It would be good to have a helper or two and build the walls full length and tilt them up. I also built some of them completely laying down, Including windows, Trim and paint and then tilted them up.
Agree
I would prefer a 6' step ladder and a taller extension ladder. Be aware that a 16' ladder does not reach 16'.
The only thing I'm not seeing,
Keith Newton
would be a drill and bits. Besides building something to hold a roof over your head, it is a good idea to bolt it down, so the first hard wind doesn't blow it away.
You make no mention of slab or bringing it out of the ground, which may add some more tools.
Jason Roehl in Lafayette, IN
But...
A 16' extension ladder will open to about 13', with a highest standing level somewhere around 10-11', so if the user is 6' tall, they should be able to easily reach 16-18'. That won't get you on the roof of a 2-story house, though.
A 24' extension ladder is fairly common and not too spendy, and will get you to most, if not all, places on a modest house. Too much extension ladder isn't necessarily a bad thing because if you only have it extended a few steps, it is much stiffer as you climb (the worst flex is always in the middle as you're climbing). Pay attention to the duty ratings on the ladders you buy. If you aren't using them commercially (only occasionally as a homeowner), you would be fine dropping down one rating. Type III is 200 lbs, but even if you weigh more than that, there's a fair amount of safety factor there.
Jason
Mike Potts
I don't see any extension cords to run your saws. You'll need proper size and length. If I'm reading your profile right your wanting to start your own company. One of the first investment I'd make would be a compressor and framing gun. If your going professional the name of the game is getting it done quickly so you can start the next job. Good luck to you
Mike
Charles Jackson III
I have a 50 ft 12 guage extension cord.
Del Williams
I found during building a similar sized building that a come-along and some hefty rope was of use as well.
Re: But...
Charles Jackson III
The 16' is just for single story houses.
Re: But...
Charles Jackson III
I am 6 feet tall.
Ron Pemberton
Charles, The Family Handyman, October 2014, has an article "How to Frame a Garage" if you are interested.
Charles Jackson III
Ok!
