I have an oak that has mushroom like (ears) growing out of it at the bottom two feet on the north side. They look almost like an ear. I have cut them off, but of course they just grow back, and it`s only one tree out of 12 that have them. What are these and how can I get rid of them? Thank You Larry
It means you have decaying wood at the site of the fungus fruiting bodies. You could dig the decayed wood out of the tree, but I'd think you would only make matters worse in time. You could take a 12" long 1/8" twist drill bit and drill into the decayed wood at different locations near the fruiting bodies and tell the extent of the wood damage, pay attention to the chips and feel of the drill bit, decayed wood is soft and punkie. Write down the depth of the drill bit when you hit sound wood.
Draw a picture to scale of the cross section of the tree at the point of decayed wood. If more than 1/3 of the cross section is decayed you may wish to remove the tree as it would be considered a hazard tree. I've seen trees last for decades after noticing the fruiting bodies.
The catch with doing a biopsy with the drill is that any decay organisms will now have access to healthy tissue. This will likely increase the decay volume. Be careful before considering this.
You can probably get as good an idea about the size of the decay by probing from the open whole. Same plan...use a probe and some graph paper.
Identifying what specific fungi you have is a challenge for anyone besides a dedicated mycologist most of the time. There are some common ones but lots of uncommon ones.
To a search on 'CODIT' to get a better understanding of how trees isolate decay.
