Tablesaw switch
Tablesaw switch
Tablesaw switch
Steve Schoene
The magnetic starter switch on my table saw (3 hp. 1 ph. 220v) has died, and I am looking for suggestions as to a source for a suitable replacement. I'm in Central Virginia, if that matters.
Re: Tablesaw switch
cheap fix
I had this problem on a 5 HP air compressor. Grizzly has some inexpensive switches but someone told me about getting the part that goes bad from a heating and air supplier. Indeed I was able to buy for less than $20 the double pole magnetic switch and swap it out in the switch box. It did take some study to figure out the wiring.
Re: Tablesaw switch
Re: Tablesaw switch
Keith Newton
Do you know how to troubleshoot the problem? If not there are lots of little things to check before deciding to buy a new one?
Re: Tablesaw switch
Re: Tablesaw switch
Stuart Johnson
Have you tried to dismantle and blow our any dust?
Re: Tablesaw switch
Re: Tablesaw switch
Larry in NW Ohio
These are fairly easy to work on, if you are any kind of a tinkerer. Most likely there is dust in between the contacts. First off disconect the plug, and then take the cover off and just look around in the box and locate the contacts, and then see if you can figure out how it works. There is a coil in it that when you push the on button the coil energizes and pulls the contacts together so the power turns on the motor, these can be worked with the power off. So you can mess around inside with the power off and try to figure out how it works. So when you find the contacts, look at them real good and see if they are covered carbon. If they are you can sand them a little and blow them off and try that, that has worked for me quite often. You may as well try it, the switch doesn`t work anyhow anyway, so you aren`t going to break it. Good luck. Just make sure and pull the plug. Larry
Re: Tablesaw switch
Re: Tablesaw switch
Bill Howatt
Problem I get with my lathe control is dust getting into the ON/OFF pushbuttons even though it looks like it shouldn't be able to do that. Blast of air fixes it easily.
Bill
Re: Tablesaw switch
I was going to suggest that as well,
Keith Newton
The start button is a momentary contact, which when pushed sends the juice through the OFF button, which is momentarily closed. If you press the START button, and the motor runs, but won't stay on, the dust would be in the OFF contacts.
However if there is power to the Start switch, but doesn't do anything when pushed, it could be dust int the start contacts.
I don't know if this saw has manual reset, or if the overload protection is automatic, so when you are in the switch box, if you see any buttons push them.
