My son is going to build a new house and is going to put a septic tank system in. One thing I heard about the septic tank is if you put one in the groun and just leave it set empty and it would rain pretty hard with nothing in the tank, it may pop right out of the ground from the rain water getting all around it in the ground and act just like ship at sea. So it should be full so it has more weight to keep it in the ground. This may sound dumb, but better than sorry. Thanks to all Larry
Q. I’ve heard that my septic tank will float up out of the ground if I have it pumped out. Is this true?
A. It is possible, under certain circumstances. If you have a concrete tank that has been in place for a number of years, it is unlikely that you will have this problem. However, certain conditions and locations increase the possibility that a septic tank might "float" to the top of the ground. Be mindful if you are in an area with high water, such as near a lake or pond. Newly installed tanks are a concern due to the loose ground around the tank. Sandy ground might also allow a tank to "float" up and plastic tanks are more susceptible. In the nearly forty years we have been in business, we have rarely seen this problem. If you have a plastic tank or you are concerned that your tank might "float" up, we suggest running 500 to 1000 gallons (for a 1500 gallon tank) of water into the system after having it pumped.
I have heard this too. I have been involved in the building business over forty years, built hundreds of houses, inspected thousands, and some of them had septic Tanks. Never heard of one actually floating. OTOH, what would it hurt to run some water into it? Let a spigot run for a couple of hours. (5 gallons per minute times 120 is six hundred gallons.)
I think the only time it might float is if the hole is in clay soil that will hold water and the hole is at the low point that would allow it to fill up with rain water. Sandy soil will let the water soak away, unless there is a high water table. Did the hole fill up with water as they were digging it?
Here, a new drain field must be capped with a large, high pile of earth with red and green lights. What you get is a distinct hill over your field that is pretty contrary to attractive landscaping, uses of your property are limited, and the darn this is a pain to mow. What the lights are for, I don't have a clue. My field is going on 45 years old and I dread having to put in a new one.
When our leech field went bad we were forced to install an aerobic system. It has 2 cement tanks and 1 plastic. Our soil is black clay and white rock mix. When the system was install they cautioned to never leave the plastic tank empty because a good rain could cause it to pop up. When we recently had the system pumped all three tanks were emptied and cleaned. The septic company said the with the weather forecast being no rain we would probably be okay if we didn't fill the plastic tank at least half full but they do not warrant against them coming up. He told me it was not common but he had seen it several times. I don't know what it would cost to reset the tank but even with the high price of water I filled it.
FWIW, if you are in an area where you can use the aerobic systems I would go that way as opposed to a standard septic with leech field.
Also, during new construction and with a plastic tank, it may collapse if equipment is drivien over where the tank is, if it is not filled. Even just dirt over an empty plastic tank could cause a bit of a cave-in in rare cases. At least that's what my septic maintenance guy told me.
That was 46 years ago. Had a small dozer, just 10 tons but it was enough to break in the tank. Back then they were building them from cement blocks with concrete slabs on top. They told me the tank and lines are over there and don't run over them. The dozer being about 7 feet across the tracks fit right down in the tank when it caved in sending water everywhere. Thank goodness it was a new house and the septic system had never been used. Rain water had filled the tank and lines.
The other was way back when I was a kid - my dad was working on a drilling project in northern Maine, and they waited til winter for some of the holes so they could drag the drill rig out onto the ice and drill through some ponds. Towards spring they managed to sink a dozer in the edge of a pond where the ice was no longer thick enough to hold the weight. I wish I'd seen them get that thing out of the mud - that would have been more educational than whatever they were talking about in school that day!
I guess the third thing it reminds me of is the old Garrison Keillor routine about the 1937 Chevy septic tank. Classic!
