Lathe problem
A.J. Hamler
Got a question on lathes -- not turning, but the lathe itself, which is why I've posted this here instead of in the turning section. I've been turning for decades, literally since high school, but I'll be the first to admit I know absolutely nothing about mechanics or machinery. I know how it all works, but when it comes to a machine's innards I'm completely helpless. I'm having an issue with my nearly new Jet 1221VS lathe. The description of the issue is as follows:
1) For some reason, a couple months ago out of the blue I started getting out-of-round turnings. Not with green bowls or something like that which will often start deforming as you turn them, but with well-seasoned wood. Happens with all kinds of turning -- spindle, faceplate and chuck turning, not just one type -- so I think I can rule out a bad chuck or faceplate but I really have no idea.
2) At about the same time, I started getting a ton of vibration. Not surprising once things get out-of-round I suppose, but the vibration is relentless. I fear the lathe is going to walk off. Even when the out-of-round issue hasn't gotten too bad, I'm also getting a lot of chatter.
3) And finally (and this may be the big clue), about the time this all started happening, the lathe started making a whining noise from the headstock. Can't pinpoint it exactly, but it seems to be higher in the headstock rather than down by the motor but I really can't be sure. The pitch of the whine changes as the speed changes.
Other stuff -- I've looked all over the inside of the headstock with a flashlight and I and can find absolutely nothing rubbing against a wheel or belt that might make that noise; it's clean as can be in there. I keep my chisels very sharp so we can rule that out. The lathe itself is very steady on the Jet steel legset (although it is, of necessity, on a mobile base); however, it's been on that mobile base since day one and I didn't have this issue then. While not causing the issue I suppose the mobile base could be amplifying the problem, though.
If I had to make a mechanical guess (a dangerous thing for a mechanical dunce like myself), I'd guess it was an issue with bearings. But as to how or why the issue suddenly appeared in a new lathe, or how to fix it or, heck, even where the darned bearings are is a mystery to me.
Any advice? Thanks in advance!
