Re: Is quartersawing walnut a good idea?
TomD
I wouldn't quater saw it, if you flat saw it you will get some "quarter sawn wood" on either side of the pith, and depending on the cuts, you will get it reasonably so outboard the pith. My preferred cuts with a chainsaw mill are to start right through the pith, since the heavy kerf wastes the most waste wood that way, but obviously your saw will be different..
What you really need to think about is the dimensions of what kind of wood you really need to get to do whatever you are doing. 12" is a little small to get too deeply into this. But for instance, assume you wanted the wood either side of the pith for frames, it could be radial in that application, and you would need what thickness pre-drying to get the finished thickness you would need for that application? What about the flat sawn wood, what is is for, and what does it need to be dimensioned at? It is hard to get specific because often when you do, the project is no longer there when the wood is dried. In that instance, and owning a band saw, I try to leave pieces as thick as possible until I resaw them, then I further reduce them when I have them dry.
Another reason to do this is let's say you need a variety of wood when you have it all dried, but you didn't perfectly yield every thickness in the correct amount. Thick wood is often more relatively expensive, a lot more, than thin wood. So if you had to go source some light wood for say panels, you might do better both in exoticness and cost, at the wood store. The least sawing yields more expensive thick wood from your home sources. I find thick wood generally dries really well also. By thick, I mean 2 inches plus or minus.
