Milestone today. The top went on and that signals the end of the building, I still have to wax the drawer sides and runners in the case. I use Carnuba dissolved in xylene.
With a false top there isn't any alternative but to screw through it into the show top. People are driven to move a chest drawers by lifting on the top, so the tap must be securely fastened. I figure that by angling the screws the top will be held by the wedging action of the screws as well as the threads.
This task presents a problem. There isn't room for a typical screw driver. However, a square drive screw driver bit fits into a 1/4" socket so one can use a ratchet wrench to drive the screws. I don't know how others solve this screw driving problem but this way works dandy.
Re: samantha's dresser- fastening the top 17 The End
Adam of Oakland
cool tip about angling the screws like that. intuitively it makes sense, i like the use of a ratchet wrench for tight quarters, too. gotta keep that one in mind. thanks!
William Duffield
That's also my method "of last resort." I don't use it as often now, as I have found a power tool that works in almost all cases, the Festool T12+3 drill kit. The offset head and/or the right angle head and/or the Centrotec head on this almost always gets me access to screw heads in tight places. Snappy makes square drive bits to fit Festool's Centrotec system, or you can easily modify a standard 1/4" hex drive Robertson head to fit. I guess it goes without saying that in these situations a square drive screw is vastly superior to a Phillips or slotted screw.
To make the drill a little more compact, I also have a smaller battery that is usually standard with the C12 models. Both drill configurations are also available in 14.4v and 18v configurations if you need more power or longer battery life between charges. If you need an even more compact system, the CXS might be the weapon of choice.
It would take several hours and many photos to go through all the options I currently have in my installation kit, which also includes a Millers Falls #97 breast drill, just in case I can't find a place to plug in my battery charger. No, the #97 would not be the best choice in the situation you show, although angling the screws, lack of dust panels and a long extension would probably allow it to work.
I have had a couple of installation situations where even the socket wrench wouldn't fit. I have found that, if all else fails, you can turn a short 1/4" hex drive bit with a 1/4" open end wrench, and if you don't have a square drive screw, you can apply pressure with a cat's paw to the end of the phillips or slotted bit, while turning it, to keep it engaged.
Took me a second to realize the picture was from the back. Duhh.
Thanks for posting this, the entire series. Its been very instructive and is motivating me to make some pieces myself.
In really tight quarters I have used the bit gripped in a very small set of Vicegrip Pliers. Works fairly well for square drive screws. Slower than a ratchet, but it works.
Larry in NW Ohio
One thing I have done to put a screw in like that, is to angle it from the back-to-the-front, so the drill is outside of the cabinet. Of course you have to watch the top so the screw does not pull the top backward. But to avoid that from happening, just put a couple of other screws in first. It works well for me. Larry
I have a couple of Sears Craftsman little ratchets which are made for these 1/4" hex bits, which brings the handle right off the side of the bit. One is straight, and the other handle is bent about 20º.
But I always like to use power tools whenever I can, so the other option, is an extension holder which has a universal joint in it, which allows about a 20º bend in the middle of this 3" extension.
A well lubed square drive will easily penetrate even hard woods. It is possible to drive one of these screws too deep and have its tip push out a dimple in the top (now how do I know that!). When driving screws in this kind of situation I have learned to put my finger on the top where the screw would poke up if it got too deep. One can feel the screw tip getting too close before there is a disaster.
To get more gripping power I have driven say a 1" screw until I can just feel the dimple forming on the reverse side, removed the 1" screw with its pointy tip and replaced it with a 1 1/4" screw with the tip ground off.
I use an 8" flex shaft that has male and female hex drive ends in a battery drill. Gets me into tight spaces were nothing else will fit to drive a screw.
but why wasn't the screw placed further in the frame? Seems like there was room for another 1/2 to 3/4 inch to not have need of the fix -- especially if the expansion hole is enlarged and the screw was angled. I've had the same problem with tight screw locations but usually with very shallow stacked drawer/trays and metal drawer glides.
Over time these have helped me. I use these after a hand drilled pilot hole using the small pin chucks as a start.. Nice project by the way.
A good application for the washer head screws like the ones for the Kreg Jig. They are square drive and have very little tendency to bury themselves into the wood.
A 3/8" spade bit or forstner bit will make a nice recess for these screws if you think ahead. Washer head screws really do a nice job of pulling parts together.
