We've been making good progress on the construction project. Cabinets are in and all the electrical work is done. Today, exterior concrete work gets started and should be finished by end of day tomorrow. I'm too tired to go on and on, but I will post a few pics very soon.
Just building and trying to reach the end of the construction project and get the MIL moved in.....
I did get some work done on the new kitchen table after last weekends lock miter experience with the table legs went down in flames I decided to just veneer the legs to hide the wide glue lines.That went swimmingly then the realization set in that I couldn't make the Blacker chair leg relief I wanted because of the glue between the veneer and the rest of the wood and it wouldn't take stain.The design took a turn from a Green and Green flavor to Mission with straight plain legs.But it gets better I started to make the stretchers or apron pieces that connects the legs together.I broke out the tenon jig and layed out the tenon , mounted the first piece in the jig a little to the left a little to the right and I thought I was ready to cut the first tenon so I start the saw and slide the jig forward and BAM $#@%@%@. .My first Saw Stop cartridge fire. IT SEEMS I was so focused on centering the mortise I neglected to center it on the right side of the blade. So one cartridge and a wasted Woodworker 2 blade later I did manage to get the tenons cut after a trip to Woodcraft. So after that I decide to ut the mortise slots in the legs so I get three legs cut I found that I had neglected to flip the legs for the second cut to make the slots have the same set back @$#%#/#%%%%. After seeing that the one slot that set back further could be plugged and a new mortise could be cut in the right position so thatwas what I did. WAITING FOR GLUE TO DRY.Other than a few bumps the project is moving along great!!!.
First, there are always little, seemingly insignificant improvements that can be made to our shops that will improve our experiences there. A case in point, after years of getting down on all fours and reaching way back under my radial arm to loosen the HTC wheel locks on my mobile base, I had a flash of creativity (a rare event) and put a couple of wood shims under the front of the mobile base. This keeps the radial arm firmly in place and allows me to simply knock the shims on the side with a hammer, then remove them, and move the radial arm as needed. No more getting down on all fours (excepts to ask to be forgiven occasionally).....
Over the years, I must have made literally hundreds of these type of improvements and they do add up.
Also, basically finished my reloading bench project with the completion/installation of the shelving unit.....
Better lighting is on the list (obviously needed). Just a footnote here: I often use the making of utilitarian pieces for my shop as an experiment for cabinets/furniture that will go in the house later and the shelving unit was used in this way to prepare for cabinets in my laundry room and later living room.
Since the weather was cool, my nephew and I cut and split about three ricks of firewood. One tree was cherry, about 28" DBH, so I kept about 6' plus the stump for lathe turning stock. My new winch and boom sure made loading the big chunks easier.
Otherwise, I did all the sawing, while he did the first loading. Then we got it down to the cabin where we unloaded, split, then reloaded it all together.
This barely left enough energy to feed ourselves. But thanks to a long cold shower and a few brewskies, we managed to get that side of salmon grilled and a good pasta salad together to finish off the day.
[uplimg]/webbbs/media/temp/3cc6a63a46f9196b871e6c82290a0ccd_2_20140804181356resize.jpg[/uplimg] Well it looks like the mortise are going to be just fine the glue plug works great.The remaining part of the plug will be on the inside of the rail. Just like it never happened but the saw blade is out at one spot .0015" according to the dial indicator and the teeth are not cracked or chipped not sure if the blade will ever be used for more than a wall clock.
I knew that eventually there would be a good use for a track lighting fixture I had replaced in a room remodel. So after years of accumulating dust, the fixture is put back into service and the reloading bench has ample light.....
Kevin.....yes, there are many good things about track lighting.....in this case, we have an 8' track with four cans.....each can has a 100 watt bulb that can be moved to redirect its light.....and we do not have to worry about heat building up in the fixture.....works well in the house and shop.
