Need a dehumidifier
Need a dehumidifier
Need a dehumidifier
Larry in NW Ohio
My dehumidifier is freezing up so I need to get a new on. Any comments on the brand that I should buy, one better than the other. This one only lasted 2 years. Larry
Re: Need a dehumidifier
Re: dehumidifier
I've tried Danby, DeiLongie (sp), and several others. Have had better service out of GE. I run two 60-70pt units in my basement office/shop; one that drains into the HVAC condensate sump, one that I have to empty. Don't expect more than three years out of any of them.
Then you get to pay again to have the refrigerant removed so you can throw'em away.
Re: dehumidifier
Larry in NW Ohio
I don`t buy anything GE. But thanks for the reply. Larry
It seems to me that if it is icing up, it would indicate reduced or restricted air flow. Could it be the unit is dirty and maybe filled with dust? Either sawdust or just dust. If there si a way to clean the coil you might get more life out of it. (The unit cools the air and that causes condensation/dehumidification. The wet coil is a very good filter. The dirt pacts up on the surface, clogging it, reducing the air flow. While the unit cools the air, the air warms the unit. IF it gets too cold, it ices up and that restricts the airflow even further, making it even colder.)
PS
was informed by service guys years ago that most all of them, regardless of brand, are made by Fedders.
ICE
Barry,
I keep mine clean with the filters pulled once a week. At the start of the "season, I remove the case and vacuum out and air-blast the coils. Icing, according to service techs, indicates that the units are either running low on freon (they cannot be recharged like a regular A/C) or the cheapo compressor is getting weak, meaning it's time to get a new one.
I have to think these things are specifically made to fail rather than last.
Re: PPS
That said, there is the Oasis brand which are used commercially, but get ready to pay $4-500 or more for one. I had one of those for upwards of 20 years that would chug along. Don't know about their current longevity however.
Re: ICE
I'm sure you are correct. It would not make sense for them to make one that lasted twenty years, even if it only cost them an extra nickle or two.
Seems odd that low Refrigerant would make them run colder, but its true. My suggestions were based on house sized AC's and Heat Pumps. Can't tell you how many I have seen destroyed by running dirty. Sort of counter intuitive, but being dirty makes them run colder.
That's Why
I have my a/c units serviced every year. Condensers and plenum coils cleaned, compressors and refrigerant charges checked and brought up to spec. Pays for itself in reduced operating costs.
You are correct....IF.....
They actually do anything. I have been to a number of houses (maybe 25) where the seller proudly presented the receipt for the recent service. Sometimes the service was literally the earlier in the same day. I inspect the system and find it to be nasty. Years of build up. Ones that are easy to see. They come there and fumble around for a few minutes, charge a fee and leave. I am sure you are checking behind these guys. If they do their job, it really does help. Does not help to pay for nothing.
Some of the local termite guys have been caught doing nothing and charging for a preventative treatment. They have actually told me that it is better to not spray dangerous Chemicals into the environment, but to wait for the termites to appear and then treat them.
Paul Blackwell
I purchased a Danby three years ago when we moved into our new house. It has two operating speeds, and you can set the desired humidity and it displays the actual humidity. When I turned it on, the basement humidity was in the 70's, and it reduced it to the setting of 50 that I had dialed in. I read somewhere that if the basement humidity is 50 or below that mold won't form. I run mine pretty much non-stop in the summer, and so far it works great.
