WC Weekend Accomplishments....
Dennis E Peacock
28 July 2014
Good Morning Everyone,
The construction project is continuing to make progress but slower than I had planned. The weather has been so hot and humid that the sheetrock mud takes about 2 days to dry well enough for the finishers to sand and apply the next coat.
We are on the new service to the house now and they stated that I had everything exactly as they wanted it...so I didn't get turned down for service hook up. Yea.!!!!!!! :D
This week, cabinets go in and the sheetrock gets finished, primer and paint go on this week as well. A lot to get done this week..but....the weather is going to be a bit cooler and making it easier to work. I still have a bit of vinyl siding left to do as well as a tiny bit of metal for the fascia as my son and I finished the soffit work on Saturday.
That's it for me, so what did YOU do this past weekend?
Best of weeks to you all.
Dennis Peacock
Re: WC Weekend Accomplishments....
Small stuff.....
roger lance
First, my lathe didn't come with a knockout bar, so, a few years ago, I made one out of a piece of oak dowel....has worked well, but the bottom of the dowel was falling apart from the metal impacts.....so I made a new knockout bar with a metal rod.....
Second, made some more progress on the reloading bench by securing it to the wall and installing some pegboard....
will now make a shallow shelving unit.....and this project will be done.
Actually got some "free" time in the shop. Since I'd done several projects but had delayed any shop maintenance and more than superficial cleaning, it was past time for tune-ups, etm. Thus each machine, table saw, band saw, SCMS, jointer, Performax, DP all got cleaned their settings checked and adjusted (where needed) to the proverbial gnat's eyelash, then all the benches and work surfaces got cleaned with extraneous stuff and tools put away and racked, and finally the floor and other horizontal surfaces and the Thomas' spaces vacuumed. With the last couple of hours I started on sharpening the ammo box of loose twist drill bits I rescued from my late FIL's garage. What I'll do with 20 nicely sharpened 1/2" bits (not to mention similar quantities in odd and even sizes down from there) I don't know, but I and my heirs won't be needing to purchase any for the next several generations. ;)
SWMBO walked in and asked how I got the cleaning crew in and out of the basement without her seeing them.
what are you doing next weekend?
I'll send my address and provide lunch. I am in such need of same!
Just a bit
outside my range, Bill. ;)
Jesper, Denmark
Re: You are not supposed to have too many clamps..
Jesper, Denmark
Having collected clamps for many years, moved them around in drawers, cabinets and miscellaneous piles, they finally got organized. The location is not ideal, as it is not immediately close to where they are used, but in the storeroom. I did consider making the rack on wheels, but i dislike another movable item on the floor, so will use a wheeled trolley instead.
For the numerically interested, there are 61 on the rack and two in use - not including spring clamps stored in baskets.
i stopped counting
terry quiram
mine after 200.
Canned vegetables all weekend. Still canning today. No end in site.
As usual, went to the cabin.. *LINK*
Keith Newton
I did a little woodworking on my cousins' cabin, like installed some cabinet doors and drawer fronts.
Picked about 50# of peaches.
I did get out for an early morning walk, and found a few sleeping dragons, but all were familiar, or more of the same as usual species. Wandering Gliders are the most widespread dragonfly in the world, and I've probably photographed a hundred of them, usually only to delete them later, but I got a few shots that I really like this time.
While I didn't post any images of these, I shot a few other unusual specimen, Mydas fly, male Velvet ant, and Owlfly.
https://www.flickr.com/photos/7391658@N03/14748410566/in/set-72157645778178044
Glue up FAIL.
Matthew W Robinette
My first attempt at using a lock miter bit to make Q/S/O table legs was an epic fail. After running the legs thru the router table with a 1/4" round over every one of the four legs four corners had a a big fat glue line. Now I am going to do what I should have done in the beginning after trimming the legs back on two sides to eliminate the glue lines apply resawn 3/16" veneer to the sides that I trimmed off.
Keith, you are the Insect Master
Yonak
(I was tempted to say : "Lord of the Flies" but thought better of it.)
I've never seen such wonderful, detailed photos of those tiny critters.
Shelving unit progress.....
roger lance
I'm making a shallow shelving unit to go above the pegboard of my reloading bench. I've made three units and am in the process of joining them into one long unit.....longer than my assembly table to be sure.....
Two jigs for this type of ww.......
roger lance
These jigs were very useful in making the shelving units. The jig on the left was one from Norm Abram.....and the jig on the right was shown by the Wood Whisperer and is used to cut dados.....
