Installing laminate top on reloading bench....
roger lance
The problem with taking pictures while you are working with contact cement and laminate is that the doing of the project keeps you busy and your photos take second place to the work....so these pics aren't the best.
Getting started.....I simply pour out some contact cement and use an inexpensive, disposable roller to spread the glue.....note that during this procedure, all windows are open and fans are going.....contact cement is nasty stuff....
Then the bottom of the laminate is also coated with contact cement.....you monitor both bench top and laminate.....adding another coat of cement when needed......and spend the down time outdoors breathing fresh air. When the cement is just tacky, I lay down a series of sticks to act as a barrier between the laminate and bench.....
Then the laminate is carefully placed on top of the sticks......note that "contact cement" is one of those apply named products.....if these two surfaces make contact, game over.....they are bonded and there is no moving them.....no adjusting them.....so now you make sure that the laminate is placed over the bench top with that excess of length/width of the laminate completely covering the top.....
I start in the middle of the top and carefully remove the middle set of sticks without moving the laminate and by hand push the laminate onto the bench and work the laminate toward one end of the bench removing a set of sticks as I go......work from middle out to avoid making an air pocket.....and also use a J Roller to concentrate the bonding pressure.....
The excess laminate is removed with a router and straight cutting bit with bearing.....I believe its called a trim bit.....then I use a chamfering bit with bearing to give the edge a little detail.....follow with a light filing to soften any sharp edge.....and you then have.....
