Veritas - Innovation in Tools
Preparing for laminate.....
roger lance
Tonight, I'm preparing the bench top for laminate which I should actually apply tomorrow.
First of all, I'm not a professional at this and things have probably been done differently since I learned to do this a lot of years ago.
In making sure that the plywood and top of the wood trim were level, I found a big depression in the surface of the plywood (I am using cheap stuff and am paying for that choice) which I filled by gluing thin strips of wood into the void and then using a plane and sander to smooth out the repair and feather it to accept the laminate cleanly.....
Next comes cutting an oversized piece from the 4' x 8' sheet of laminate. I use a small router with a bit from an in-lay kit to rough out my work piece which is 4" oversize in both length and width.....
In adhering laminate, dirt is your enemy.....so clean, brush, wipe, vacuum the work surface and the work piece top and bottom to make sure no dirt particles remain. The glue down comes tomorrow.
Re: Preparing for laminate.....
Is that plywood actually flat?
Dick Coers
And if it's flat now, I would not be confident it won't change with a humidity swing. Good luck!
What plywood is actually flat???
roger lance
I've never found a truly flat piece of plywood.....regardless of price.....for that matter, wood is never truly flat....you may get it reasonably flat but thats the best you'll ever do.....and will it change with humidity???.....thats the nature of the thing.....so keep your wishes of luck.....they aren't needed.....but, if you mean is that "repair area" smooth ??.....yes it is.....its feathered out and the end product will be fine.....I built this reloading bench with #2 common framing stock and I expect it will be alive and kicking for a long time to come.
Small Suggestion
Since you are laminating the top surface (with HDL?) I suggest that you seal the underside of the top. 3-4 coats of shellac should do. Reason being the laminate cuts off all moisture gain by the top surface, but the raw bottom surface will be free to suck humidity out of the air and swell. You want you laminated surface to stay as flat as possible so sealing the underside will only help. Mica'd cabinet doors must be laminated on both sides to keep them flat for the same reason. 3-4 slop-coats of shellac is cheap insurance.
PS
Bondo auto-body filler makes a great leveling compound and is way easier than gluing stips of wood in low spots
Re: Small Suggestion
roger lance
Mark...thanks for the suggestion.....this is really a utility piece and it has a large, heavy wood frame to which that plywood is securely screwed.....not unlike my planar infeed/outfeed tables which have that same laminate surface.....
so far so good.....and its been years ago when they were made and the humidity is high now with no apparent degree of distortion.....but some shellac maybe in order.....can't water penetrate shellac??
I've used bondo type products on repairs to siding etc .....but was a little worried about possible chemical conflicts with contact cement and, frankly, this was the first time I've ever made a "repair" like this to plywood.....just showed it as an example of problem solving.
Shellac
is one of the most water-resistant finish films we have so a few good slop coats under that top will do you fine. When I made lab-grade Formica tops they were always laminated on both sides to keep the working surface dead flat. Same with kitchen counters. We used "backer" sheets with were 2 layers thick, essentially thinner HPL but without the color/feature layer to function as a moisture stop.
BTW, you are using the solvent-based, brain-melting contact cement, right? ;)
Re: Shellac
roger lance
I'm afraid so.....when I was at the big box I looked for water based but all that they had was the "original"......all windows will be open....a fan will be running.....and I'll be moving out of there without admiring my glue spreading abilities.....the bench is just a little big to carry outside by myself..... :(.....but maybe another run to the store would be a good idea to get the friendlier product and save some brain cells which may come in handy in my golden years.
Flat Glue
Good!
So . . Take about half of what you think you'll need and cut it 50/50 with lacquer thinner. Using a 4 inch "chip brush" apply a first coat to both the wood and the laminate. Allow to dry well and repeat several more coats of the thinned glue until you get an even sheen on both the wood and the laminate. Allow the last coat on the wood to dry to a nice "tack" before applying your laminate. This insures that you'll get even and complete adhesion across the surface but with no glue lumps to try to roll out.
Curl your laminate on the long axis and work it down across the short dimension, then roll with as much pressure as you can apply. I always used Memsahib's rolling pin.
Re: Flat Glue
roger lance
I'll be using the old school method of placing sticks on the bench top when its just tacky and then positioning the laminate to make sure I have coverage and then start removing sticks in the center and work the laminate down and out to the ends with a J roller. These projects go on and on don't they.
PS
Flat glue layer is especially important when working with BigBox material. I have yet to see true counter-top grade HPL in their inventory. All the material I looked at was vertical grade which is thinner than product meant to take the use of a counter top. The thinner laminate will telegraph lumps and bumps to the top surface.
Got a burr under your saddle Roger?
Dick Coers
When I offer someone good luck on a project, I mean it. If you don't want any comments on your work, I suggest you say so in the post.
Re: PS
roger lance
Agree.....when I bought this material, I thought it was thinner than what I got before (which is a long time ago).....also in the past, they sold laminate in various sizes....now, you have to buy the whole sheet. I'll get things as clean as possible....utility piece or not, we want to do a good job.
Great suggestion Dick.....
Questions for Mark on Contact Cement
Mark, You seem confident in your answers on Contact cement. Your approach and experience seems to be different from mine. I'd like to learn something here.
You do mean you like the solvent based version of the glue? (I have not had good luck with the water based or whatever version.)
And, applying the glue thinned? Getting a very thin layer with the sheen? This works well for you? I am missing something here. My experience is to apply the very thin coat and then come back later with a much thicker coat on both pieces. I have had failures with the thin coat only. I apply the coat especially heavy around the edges. Then roll it as hard as I can. If I get a loose spot at an edge I have been known to apply a clamp or two and let it sit for a day or two.
The Pro shops I deal with have a glue applicator like a spray gun that slings on a thick stringy coat.
When I have used the 3M stuff in a spray can I have had to apply several coats and especially heavy around the edges
Re: Shellac
If you want it to stick reliably use the "name brand" solvent based adhesive. People are exposed to these solvent systems vastly more than you will be without harm.
I have never see a kitchen cabinet counter top treated on the back side to deal with curling. Apparently if the top is secured the plywood stays flat. We always just nailed the tops onto the cabinet frame with coated nails.
Re: My Method
I've laid up a bunch of mica and never had a failure. The first thinned coat penetrates into the wood surface better so the bond with the wood is more than surface stickum, and does a better job of wetting out the laminate surface as well. Multiple coats is the key here as you wind up with the same amount of glue coating, but with the glue layer even. This is really important when working with thinner laminates.
My reference to a "sheen" may have been a bit misleading. I'm not talking about what you'd see with a coat of thin shellac sanding sealer. On plywood it will take at least 3 applications to get a real shine such that any wood texture is hidden under the glue. Same for the laminate. Think "finished" table top with the dried coating several mils thick on each part.
Couple of points:
a. Since we are in the humid Summer, care must be taken to allow a coat to dry before recoating. Otherwise you risk blushing (just like with lacquer) which will trap condensed moisture between the glue layers and weaken the bond.
b. Putting extra around the edges is fine, but again, you want just enough glue to make a strong bond. Too thick a layer at the edges can lead to degrading the glue over time and you'll get the laminate lifting, especially at the corners.
c. I prefer the "team" approach (4 hands) to putting the laminate down on anything over 3' in any direction. I bend the plastic into a "C" shape then position it along one edge with an even amount of overlap, then press it down onto the surface letting the C straighten out as you roll it on along a line away from the first contact edge. This prevents trapping any air under the laminate which, once the sheet is down, will not roll out. Any air bubbles will be there forever DAMHIKT ;)
I worked in a factory shop one summer and they used spray applicators as well (hand application takes too long on a production line). They also adjusted the glue viscosity depending on the weight of the laminate being used and a roller press to put laminate to prepared substrate with a lot of pressure.
Thank You....
This is one of the the things I love about Wood Central. The Knowledge Base here is vast and I learn something almost every day.
I will try your method.
Psst
No pun intended, Barry, but do not try to use spray can adhesive to put down HPL. Far too little "solids" to form a proper glue layer in such an application. Just 'cause it's sticky doesn't mean stuff will stay where you put it.
Don't like the bond contact cement gives at edges
Tony Haukap
I have never cared for the bond strength contact cement gives at the edges. Seems to be the contact cement bond is pretty low overall and is prone to lift the laminate at the edges, especially if it gets bump in just the right way.
I don't remember where I saw this tip, but this has become my standard method of working with laminate...
"Mask off the perimeter edges of the substrate with 2" masking tape. Contact cement is applied to the field, then the masking tape is removed and white glue (white instead of yellow glue for the open time) is applied to these areas. This will allow the instant bond in the field leaving the edges to be clamped using conventional methods."
Since going to this method I have never had an edge come loose and a few times I tried to pry the laminate off it was impossible without damaging the substrate - whereas before I could get a putty knife under it and pop it off without much effort. And yes, this is with solvent based contact cement.
