Refridge fix
Refridge fix
Refridge fix
Larry in NW Ohio
About a year ago we bought a new Samsung fridge with an ice maker in the top fridge and in the bottom freezer and almost imediately the freezer temp got down to -14-to-18 degrees, needless to say the ice cream was rock hard. Nothing I did helped. So I called the company and they had me do some more things and that didn`t help either, so I called the company again. So they sent a technition out. So the tech came out and he changed the ice maker, it was clogged full of ice and would not work right, and the tech said that is where a computer is. He left saying that should do it. :\ So I put a thermometer in the freezer with a reciever on the outside. Over the next week or so I keeped track of the temp. Well the temp was better but still got down to something like -10, colder than I liked it and the ice cream was still fairly hard. So I messed around with it and thinking :( about it and finally come up with the idea to shut of the top ice cube maker and that has kind of taken care of it. At least the ice cream is not as hard. So if you got this brand of fridge and having this trouble, you might try this. It has worked for me. I guess from reading their site a lot of people are having trouble with this. Larry
Re: Refridge fix
Re: Refridge fix
Bill Turpin in WNC mountains
Are you eating real ice cream? Fat and sugar both act as antifreeze in ice cream. Leave them out to save calories and the ice cream will get hard enough that only an alligator has enough jaw strength to eat it. If you are afraid of calories, buy real ice cream, eat less! Have fun :)....I am watching program on TV about Florida gators.
Re: Refridge fix
Re: Refridge fix
Dick Coers
Our Whirlpool doesn't work as well when the ice maker is on either. It's a side by side with ice maker in the door. It runs too much while making ice. It will get an ice buildup on top of the ice maker and between the door. The door seal passes the dollar bill test, so don't know why that ice builds up there. There is a plastic duct that channels cold air to the ice maker, that may be out of alignment. It also filled the pan under the refrigerator to overflow last summer. If you do much research, seems like ice makers are the number 1 problem with most brands.
Re: Refridge fix
Re: Refridge fix
Larry in NW Ohio
Dick As I said in my post, I think, in our fridge the ice maker will build up ice when you get ice for a drink from the door and as it sets there over time and the fridge goes thru a frost cleaning cycle the ice will melt just enough the ice will melt very little, and then when it freezes again they will freeze together and make a clump. At least that is my conclusion of it. Then that really messes the mind of the computer. At least that is what I took from the tech when he tried to explain it to me. The computer thinks it needs more ice fairly quickly so the computer goes into high gear, in other words the cooling system goes way down something like -15 degrees or more to make ice more quickly, and there you have it frozen hard ice cream. IMHO Larry
Re: Refridge fix
Re: Refridge fix
John Veerkamp
In our Maytag(maker of Whirlpool) we have a similar problem. According to our Really good repair person, the fix is easy with most models. Empty the in door ice bucket weekly. Doing so keeps the whole thing from becoming a solid mass. Longer intervals in winter are ok. Since I started this, no more problems.
