How to compress bulging bookcases?
Brint in Richmond, VA
After the top shelf on this bookcase fell down for the third time in a year, I took a closer look and discovered that the case sides had begun bulging outward.
In all fairness, these bookcases have served me very well for over 25 years, especially considering that they're made of veneered particleboard.
Each shelf has a groove cut into each end, which fits over removable wire supports that stick into pre-drilled holes in the case sides.
In bulging outward, the sides have pulled the wire supports out far enough from the grooved shelf-ends so that they lose their purchase and the shelf falls.
Regrettably, there is no fixed center shelf to keep the case sides together; if there were, then I likely wouldn't be having this problem. That said, I'm leery of trying to glue or screw in the center shelf now as a way of bringing the sides back in, simply because I'm working with 25-year-old particleboard all around and I'm not confident of its holding power.
In my dreams, I simply affix a 12' invisible pipe clamp to the center back of the three bookcases and squeeze them together. In reality, the only immediate solution I see is to fashion myself some new wire supports that extend farther in (toward the shelf grooves) from the case sides than the current ones - but then I'm afraid the sides will continue their bulging journey outward.
Does anyone's experience with particleboard suggest that fixing the center shelf might actually work? The shelves are 30" x 11-1/2" x 5/8". Thanks to anyone who can offer a suggested remedy.
