Veritas - Innovation in Tools
OT, Be careful what you wish for, *LINK*
Keith Newton
Last night, I was reading an article about the California drought, feeling a bit or angst or empathy, then later read about signs of a coming El Nino. I was searching through the cobwebs of my memory , trying to think this would be a good thing for ending their drought.
After my curiosity was aroused, I found a site with charts and list of past El Nino and La Nina, which I will link below. While I was studying this, I started looking for marker years for my area from memory. Then it dawned on me that I use another NOAA site regularly to monitor the river levels down at the cabin, especially during flood periods. Not only does it show the current river level, it forecast out about a week. But it also list past significant floods over about 50 years.
After looking at this for a spell, I finally made a list of flood years, then comparing it to the other, I found of the 6 strong El Nino, 5 were flood years here. Of the 8 moderate periods, 7 were flood years also. There were also a few floods which were in the La Nina cycles, but low on the flood list.
Also of interest, was that our hot dry years occurred during the years in between the peak cycles.
Down here in my area, Arkansas, when the wind is out of the S, it is bringing warm moist air off the Gulf. Then when cooler air comes down from the N, it slips under the other forcing it up, dumping the moisture in the form of rain. It is kinda hard to get my mind around how ocean temperature that far away in the opposite direction could affect our weather here, but it obviously does.
I thought I would share this info with my friends here, and suggest that you go to the second link, find a river near you to find a river level monitoring station, there you can find a list of historic floods to compare to the first link to see if it affects the weather in your area.
Last week I was at my sister's home. We watched a 2 hour NOVA program about how much of this stuff is monitored from space. This program was incredible, and I need to watch several more times, because there was just too much to absorb in one viewing.
http://water.weather.gov/ahps2/hydrograph.php?wfo=
Re: OT, Be careful what you wish for, *LINK*
Keith Newton
Humm, I just noticed the second link is missing, so here it is again. This site is upstream of us, but is easy to navigate, to plug in your location.
http://water.weather.gov/ahps2/hydrograph.php?wfo=lzk&gage=cama4&hydro_type=0
Larry in NW Ohio
Keith and Bill I read your 2 posts and in Bill`s there is a highlighted word that pops up, clearance, and it has an arrow pointing upward and ad pop`s up for something that is quite questionable. I`m sure neigher you put in. Is there something wrong with my computer or did it pick up something on the way here. Larry
Keith Newton
Larry, I don't see anything on my computer like what you describe in either thread. Sorry I'm not much above computer neanderthal level.
Larry
That auto-link deal is actually in your computer and you should look into removing or having it removed.
m
Re: Larry
This is exactly what the Tuvaro program I posted about recently was doing to my friend's computer. It was an invasive program apparently known as a PUP, or Potentially Unwanted Program. Someone posted a link about it with a Long explanation about how to remove it. I tried to follow the instructions, but got lost at the very beginning. There was link to a program that would remove it in the post and I downloaded the program. I watched the associated video, but the narrator was clearly fluent in some language other than English. I just barely figured out how to run it. Took an hour or more, but it finally did the job. That was about week ago and it has not reappeared.
Re: Larry
Larry in NW Ohio
If anyone knows of an easy way to get rid of this PUP I would appriciate it. Thanks.Larry
Have you tried Malware Bytes?
I never get any malware or PUP infections, whether or not it's because I'm lucky or because I have Malware Bytes on all my computers, I can't say.
If you know the name of the program, google it and you'll find removal instructions.
R:Ellis
Larry in NW Ohio
The ad that pops up in the popup window says Ad by: Browser Guardian Does that tell you anything. it doesn`t tell me anything, because I`m lucky to turn on the computer when I sit down in front of it. I hope someone can help. Your post really sounds good Ellis. It sounds simple to use. How and where would I get it? Thanks Larry
Google is your friend *LINK*
I have never heard of that adware program you mentioned. Whatever it is, it isn't coming from WoodCentral and you didn't get it here. I googled "Ad by Browser Guardian" and the very first link was to this page, which tells you all about it, where you probably picked it up and what to do about it. The instructions are very detailed.
Remove Browser Guardian
