Drawers Stuck question?
I built a chest for my nephew. Graduated drawers. Bottom one is about 8" deep and the top on is about five. Finished the chest about two or three months ago and Set it in an unconditioned space waiting for pickup. Yesterday my sister and BIL came to get it. The larger drawers were stuck. I had them set up with about three hundredths clearance. I am assuming they swelled due to the wet summer and humidity. They took the chest and will put it in an Air conditioned space, and wait and see if they shrink.
Any chance? Any suggestions? (Next time I will check before they come,. but I was afraid to trim the drawers for fear they would shrink and be too loose.)
Re: Drawers Stuck question?
Keith Newton
I would take the drawers out above, then use a hair dryer to warm the stuck one up from the inside. Don't expect to do it all in one try, but do it off and on every half hour or so. The warm wood surface will take the moisture with it as it cools.
Ralph Lipeles
Your clearance is pretty tight. The desk I am sitting at has drawer clearance close to 1/8". Why not open it up a bit so that it will be less sensitive to humidity changes.
Re: Drawers Stuck question? *LINK*
Dick Coers
Sure, it will shrink and swell every year. Drawers that big should have quarter sawn wood for the sides, and of course, use a wood shrinkage calculator during design. I don't think just a hair dryer will do the trick. I would build a plastic sheeting tent over it and put in a dehumidifier. You will get heat and then moisture reduction that way.
Wood shrinkage calculator
Stephen Kirk
Yeah, here in the NorthEast I use at least a 1/16" of inch clearance, if not a bit more. Sure it may be a bit loose in the middle of the winter, but at least it still opens in the summer.
Sitting in an AC'ed house might pull enough moisture out that it'll move again, just have to wait and see.
pecker
Some of my shop cabinet drawers seize up in the summer , then work smoothly in the winter. So I think the idea of just letting them acclimate to an air conditioned house for a while is a good one.
don stephan
Using a single species of wood, for example ash, edge glue and crosscut to make a stick 1" long by 48" wide by 1" thick. Hang from one end and note the change in length over a year. After that year, you will know where your stored wood is in terms of annual expansion and contraction. With a wood movement chart you can calculate about how much a drawer side will move during a year. Finally, estimate how much drier or wetter the climate is where the furniture will be used versus the climate where the furniture is made. This was presented very well in a FWW article or sidebar by Chris Becksvoort several years ago.
don't agree
"idea of just letting them acclimate to an air conditioned house for a while is a good one."
Fix it! Drawers are easily fit after they are made. There is no excuse not to refit a sticky drawer. If you don't know how to set up and use a hand plane this will be an opportunity. Read and believe the cap iron article in the Articles section by Weaver and you are in business.
I purposely acclimate drawers in a high humidity location and do a test fit after they have swelled to as large as I hope they will ever get. I just recently had to take another few swipes of the hand plane to the largest drawers in Samantha's chest of drawers. This 8" drawer was fit with a 1/32" gap of height at 60% RH and it just began to drag a bit at 80% RH.
roger lance
Since I work a lot with QSWO, I made a gauge stick as Don described to help plan for expansion/contraction issues of furniture parts. The same could be done for drawer stock. Try various ways of drying your project. Hope you succeed. Lesson learned.
