Finish
Joe in a Cleveland suburb
Thanks.
The finish... well, I am horrible at finishing a project (meaning both completing and putting a finish on the project), and I don't keep notes or anything on how I made and finished a project, so I am going by (very bad) memory here...
For the (Cherry) base I simply wiped on a coat or two of BLO after sanding. After that cured for several days (maybe a week or more by the time I got around to working on it again), I wiped on a few coats of (left over) Behlens Rock Hard Table top finish that I had thinned with mineral spirits. Then I put a little wax on it with 0000 steel wool.
I was going to use Waterlox on the base but that stuff is pretty pricey (to me) and I always end up throwing a lot of it away (goes bad before I use it up).
For the top, I cut it to shape on the BS, then planed it to final thickness and finish planed it baby butt smooth. Then I applied (very) diluted Transtint Early American Maple. After it dried a couple days, I sanded and scraped a lot of it off leaving it mostly down in the grain. I also saturated it with BLO. I kept putting it on until it seemed like it wasn't taking anymore. Wiped it off.
Let it sit several days. Then started to brush on plain old MinWax gloss poly. I got side tracked for a couple days and went back to put more finish on it and discovered I had forgotten about my brush. The poly had cured hard as a rock on it.
It was my favorite brush; I bought from Jeff Jewitt a number of years ago while visiting his shop here in Cleveland. So, I had to go get another brush from him. Guess it was time anyway.
I sanded lightly between coats of poly. The final coat came out perfectly. Tipping off and a quality brush makes brushing poly so much easier.
I really hate finishing. I do want to get into and learn spraying. I kept notes and links from the discussions we had here last winter about spraying, but living in the city with houses sooo close to each other, I am really concerned/worried about overspray going into the neighbors yards, cars, houses, babies...
Thanks.
Joe
