Anybody tried Harbor Freight Sandpaper?
Went to Harbor Freight this morning for something else and stumbled across their sandpaper. I bought two 10 sheet variety packs just to see if it was worth it. Anybody tried it?
Re: Anybody tried Harbor Freight Sandpaper?
Jesse Cloud
I haven't tried it and would be wary. Quality control is critical in sandpaper. The grits need to be very consistent. If they are a mix of the labelled grit plus some coarser and some finer, you will find that you need to sand much longer - most likely until you just give up and move on.
I believe in the saying that cheap paint is no bargain, and that applies to sandpaper, too.
But, having said that - I'm glad someone is trying it. Let us know!
The "More" for "Less" folks......
roger lance
generally, my experience has been, I get less for less......good luck though.
Wary is good
I rarely go to Harbor Freight, but I'm always attracted to the bargains there. Last time I dropped by, I looked at their sandpaper and saw nothing I would buy, for whatever reasons occurred to me at the moment. Your mileage may vary. Please let us know if you find a bargain there.
I am Wary....
This stuff was so cheap I bought it on a whim. I saw some At 1000 and 1200 grit in silicon Carbide. Actually looked pretty good. The mixed pack for wood working, not so much. One pack I picked up, the top sheet felt dull, the second pack was a different color and it felt sharp. At 30 and forty cents a sheet, what the heck? Got $7 in 20 sheets. If it turns out to be worthless I can always use it for TP. NOT!
most reviews say the grit falls off quickly
Dick Coers
I haven't tried it, but most all reviews I read say they end up throwing it away. I've never used cheap sandpaper. Either Norton, 3M, or Mirka for me. I do love the free flashlights though!
Terrible stuff.
I have purchased some "cheap" sandpaper before, can't remember, but think it was from Big Lots, similar to HF quality. Also have some I obtained at auctions in boxes of woodworking items. In every case the only thing I have found it useful for is to remove rust from metal parts where I am not trying to obtain a good finish but just to make paint adhere properly. In my experience non of the sandpaper worked well. Paper backing was brittle, grit adhesion poor and you could visually tell the grit size varied. I really don't enjoy sanding, and typically have a lot of time invested in a project by the time it is in the sanding stage. I just can't see investing the dollars in wood and hardware, hours of time in a project then trying to save, at most $5 ~ $10 then end up having a poor finish. I usually pre-sand or scrape prior to assembly, in many cases it would be quite hard to correct poorly finished/scratched material after assembly (or finding it after applying the finish).
I have a pretty good stock of sanding disks, flat paper and adhesive backed abrasive material from Klingspore's and will continue to restock from them.
In my opinion trying to save a buck by buying cheap sandpaper or finishing coatings is like making a cabinet that takes 40 hours of labor out of common pine instead of a quality hardwood to save $40 ~ $50, just isn't worth it to me.
Basil
I haven't been in one of their stores in at least a couple of years but....
https://www.woodworkingshop.com/?inMed=BSANDING
....used to have a large box of sandpaper scraps in their stores that they sold by weight or bundle. All kinds of sandpaper in that box. I still have a lot of short rolls that I have made strips from for my drum sander.
Does anyone know if they still do that?
Klingspor's bargain box - yes
Henry W
Basil - yes they still sell assortments of abrasives by the 10 lb box. If you follow the link and see the right sidebar, they also sell other bargain boxes (i.e. 20 lb; hook and loop; adhesive backed, etc)
http://www.woodworkingshop.com/product/bb00010/
I am fortunate to live close enough to a Klingspor's retail store (three of 'em in NC) that I can pick through their bargain bin of abrasive offcuts that are left over from making sanding belts; it is available by the pound. Their gold product is great for sanding turnings because the backing is so flexible and 'foldable.'
Henry
Re: Klingspor's bargain box - yes
Basil
I'm about 45 miles from their store in Charlotte. I have bought plenty out of the bargain box.
Love Harbor Freight, but...
Joe Pack
Harbor Freight is great for some things, particularly "one time/limited use" tools, tarps, "no-brainer" stuff, but, in my experience, the sandpaper is all but useless. The grit falls off almost immediately, the backing is terrible and it is generally a waste of money.
I skimp on lots of things where quality is not key, but trying to save a few pennies on HF sandpaper turns out to be pennies thrown away.
I've tried it... once!
Pat Evans
Once was all it took to find out their sandpaper is junk. Grit just about fell off. Useless!
steve mackay
Their belts are OK, "snot blocks" are good, sand paper, not so much.
TomD
Maybe not sandpaper. Just went there for the first time in about ten years. Surprise! No outstanding warrants for someone else attached to my file at the border.
Spent a ton, and already used the first thing I bought to reassemble a watch. Unfortunately, the battery had run down in the time spent waiting to assemble the watch!
