WBpoly/Oil Stain Follow-up--Pedestal Table
Alan Young
Alan Young
Here is the end result of several weeks worth of work spread over several months! My small shop was pushed to it's limits this late winter early spring when commissions from two clients plus a few "smaller" projects challenged my abilities to juggle space and work flow in my shop.
The first piece was this 7ft long 26.5" w and 35" h Walnut Wetbar. This pieces was designed for a 100+ year old town house that was totally gutted and refurbished for a living space. I had to accommodate the work schedule of the GC. This required the piece to leave my shop before the "finish" was finished. The piece is completed but this is NOT the finished look
Having the main carcass out of the shop was a space saver as I was working on a cherry pedestal table which was the topic of a question on WB Poly applied over an Oil Stain...
http://www.woodcentral.com/woodworking/forum/messages.pl/page/1/md/read/id/479387/sbj/will-enduro-water-based-poly-work-over-oil-stain/
I had just applied the first topcoat of Oil based Poly over an oil stain when I noticed (too Late) there were some small surface defects that I had failed to sand out. This pic doesn't really show the defects but it's all I have of the processes.
After reading responses from Mssrs Mandel and Corell in my post in the thread above, I proceeded to strip the entire finish and start again. I sanded the entire piece thoroughly through 220 grits-and did my best to eliminate the defects I had missed earlier. I re-applied the Oil Based stain (Minwax Red Mahogany) as that was the client's chosen color. I let that sit overnight then sprayed a coat of Sealcoat toned with Transtint dye (to carry the color through the WB Poly) and sprayed several coats of Enduro WB poly (semi-gloss)...
Here's the result:
I have an inexpensive turbine HVLP unit and my spraying technique needs some refinement but the end result is vastly superior to the finish I was staring at last Friday Morning. My Thanks to Mark and Robin for their comments which lead to a much better outcome.
-Alan
Re: WBpoly/Oil Stain Follow-up--Pedestal Table
Tony - Memphis
Nice work! Thaks for sharing. I really like the finish on the pedestal table. To me, that "satin" look is just right.
Tony
Yup
Looks like a piece of custom furniture rather than plastic-coated wood! :D
Well done, Alan. Gotta love it when a plan comes together. ;)
Dick Coers
Looks nice. I'm sure not a fan of staining walnut though. That's some kind of beautiful wood to be covering with that dark of stain. You probably could have used poplar and it would have looked the same. Just a personal preference.
Alan Young
Generally speaking neither am I but
Alan Young
this was actually Cherry-The Pedestal Table that is...The first piece show in the post-Wet Bar-is in Walnut...Client driven look-$o That$ why :^)
-Alan
Joanne in Point Pleasant, PA
Nice finish! I just used WB poly on the sideboard I posted last week. I hate that stuff. I used a brush for most coats and finished up with a good foam brush. Still not happy with it, but I do not own a sprayer. May have to get one. It would be good for the shellac or other things I usually use as finish.
Hand Application of WB
Do Not use a foam brush with waterbornes, it puts too much air into the wet film. A good nylon or Taklon brush with split ends will do the best if you can't spray.
I use a foam brush successfully
I refinished my kitchen cabinets in place with a foam brush. Ditto for a cabinet section at daughters. I had no problem at all with bubbles.
WB + Foam Brush
Not surface bubbles but rather very fine air, like cloudy tap water that clears with time, that will be trapped because the coating dries so quickly. You can wind up with a loss of clarity in the finish film.
I don't see it
I get the effect your describe if I foolishly shake the can but not brushing, "brushing" in one direction with a very wet brush. Target urethane.
Re: I use a foam brush successfully
C. John Hebert
There are 2 types of foam brushes out there. There's a course and a fine dense foam. The later is the better one for almost flawless finishes
I Quit Hand Application
of waterbornes years ago. Tried with Target, Fuhr, and General finishes (a few others that I won't mention). OK on small stuff and things like legs, but brush strokes and lap marks were persistent and unacceptable on larger surfaces. Since I also tone finishes, spraying is the only way to avoid lap marks.
Re: I Quit Hand Application
C. John Hebert
Oh...I spray most everything now. but also applied my share of hand finishes long before spraying. The key for flawless finishes with foam or brush is to wet the entire length, then make one clean up pass the full length to hide any lap strokes. Of course...it needs to be done before set up occurs.
Agree on spraying, but......
when refinishing the kitchen spraying would have been difficult in the kitchen. Indeed, I took the doors and drawers outside to spray them but the cabinets were coated in place. Brushing was a practical alternative using technique John describes.
Re: Hand Application of WB
I had read that online somewhere, but I did not like how the brush looked. The foam seemed to make a much smoother finish. I'll know more in another week when I rub it out.
