Here is a shop accessory you won't find in the Lee Valley catalog. I hope this post inspires other to contribute how household items find employment in their shop.
This discarded wastebasket is handy way to store sticks I used between clamps and panels while gluing up panels. The clamps dent these sticks and not the panel edges. The sticks come from ripping panels to width.
- -and, if you want to pin a rung to a chair frame, they will do a great job. I use my chop sticks to stir varnish, mix epoxy, etc. Can't live without those wonders of the East. Philip
Plastic container lids make great bench coasters for glue rags, coffee cups, paint cans, small parts and fasteners, sweaty Coke bottles and anything else you don't want contaminating your bench top or escaping to hide in a pile of shavings. I keep a stack of them handy and use them all the time.
Ziplock freezer bags work real well to stow screws, jig parts etc., they even have a "write-able" surface area so you can identify. Also Pill bottles (I have a tooo large supply as I age) also are handy for storing extra router bits, drill bits and parts /pieces.
I store wipe-on finish application rags in Ziploc bags between coats. When I'm done, I just leave the rag in the sealed bag. The bag restricts the oxygen that gets to the oil so the rag dries slowly in the bag with no heat build-up. When it gets hard, I toss it into the trash. Easy, no mess.
Since reaching the "medication age" I'm stockpiling little jars and I use them for all kinds of small things too. Easy enough to put some holes in a board as a hanger, too!
Old plastic cutting boards - drill slightly over 1/4" or 1/2" holes and they hold router bits. I put some plastic stand offs in the corners and screwed it to a board.
Plastic yoghurt containers for mixing epoxy, finishes and stains, etc.
Potpourri hot pot + wide mouth jelly jar + candy thermometer = hot hide glue pot.
Steam iron for gluing down veneer, steam bending wood strips, steaming dings out of wood. (You don't want to use SWMBO's!)
Coffee warmers for melting wax, hot melt glue, liquid hide glue, etc. Don Williams offers this tip: Pick several of them up at flea markets, garage sales, etc. Put a cup of water and a candy thermometer in each one and plug it in. When the temperature stabilizes, write the temperature on the coffee warmer. That way, you will have an assortment, with an assortment of temperatures appropriate for melting different materials, without the risk of overheating anything.
For sanding intricate shapes, I cut my sandpaper sheets into ninths. Synthetic steel wool (ScotchBrite, for example) gets cut into the same side squares. I keep an assortment of grits in plastic CD racks, like these, for example:
