Failure at Basic Shop Safety
Doug Reynolds
Two weeks ago a coworker came over to my house needing thin stock for box making. We re-sawed some big leaf maple on the bandsaw and, then, were using the Performax 16-32 to remove the saw marks and get down to final thickness. He was at the far end catching the wood and I was doing the in-feeding. It seemed to me the in-feed table was just a little high so, I grabbed a box wrench to loosen the bolts and lower the table a smidge. As this was going to take just a minute I saw no need to turn off the conveyor and drum. I'm sure you can finish the rest of the story but, I will continue. The wrench slipped off the bolt head and, my hand flew forward toward the gap between the in-feed table and moving conveyor belt. The conveyor belt grabbed my thumb sucking it into the gap and, drawing my thumb up to the first joint which was too big to fit past the gap. The sandpaper conveyor belt then just sucked the flesh off my thumb degloving it almost to the bone and, flipping the large chunk of flesh up and over the tip of my thumb. I was able to reach over the in-feed table and turn everything off. My co-worker was able to remove the bolts, remove the in-feed table and, free my thumb. I called 9-1-1 and, as the fireman bandaged my wound, my friend went around the house cleaning up the puddles of blood. Luckily, he was there otherwise, I don't know if I could have freed myself. He then drove me to the E.R. were I was stitched up. The hand surgeon believes I should have full recovery after many weeks in a splint and therapy. I had to cancel two chair making classes at the Port Townsend School of Woodworking. Moral of the story, "Be sure to read, understand and follow all the instructions that come with your power tools" and, most importantly, turn the darn thing off before you make any adjustments. If I knew how, I'd happily share the just before stitches photos.
Re: Failure at Basic Shop Safety
Geez, Doug, I'm not sure I want to see those pre-treatment photos. Sounds like a real disaster. So sorry to hear about the accident, and I hope your doctor is right about a complete recovery.
I think about safety every time I use one of my machines. Now I will redouble that effort.
Mark Meier (Ann Arbor, MI)
Sorry to hear about your accident, Doug.
Consider posting your story on this site: WWA Accident Survey.
I've learned many things not to do by reading about the accidents of others.
Mark
James Heaston
Didn't get any blood on the wood didja?
What I'd hear from Dad every time I'd spring a leak.
Glad to hear you'll make a full recovery. :)
Doug Reynolds
No wood was hurt nor "stained" in the process. I just hope those reading my experience can let me do the bleeding for you and, as Ellis says, be careful. Like so many accidents, it was avoidable and happened in a split second. I don't think I could recreate it even if I tried.
roger lance
Doug.....I'm sorry to hear of your injury and hope you have a full recovery. Above this thread is one involving RASs which are often characterized as "unsafe" tools. But the truth is that woodworking is a dangerous activity and a person can be hurt/injured by just about every tool (including hand tools) in the shop. Get better.
TomD
I got wound up in a small drill press last year, a tool class that I have had serious encounters with before. It was a 25 dollar unit. I haven't hooked up my 5 HP 3 phase Buffalo Forge press yet, and maybe I never will. The problem in my case was gloves. I never wear gloves, except sandwich making gloves when there is oil around. But everyone these days seems to wear those mechanics gloves, so I gave it a try...
I do think that bad stuff happens, it is pretty hard to actually work in the real world and not have the odd accident. It isn't an OSHA workplace, it is somewhere between that and climbing the Shield on El Cap. You don't grow if you don't try new things, and occasionally try things that OSHA wouldn't like. You just have to have an "on point" mentality all the time. I have kids spread out over decades now, and I never relax. I am always on the lookout for them, even if I didn't have a shop.
The key is to call other people stupid when they get hurt, it makes most people feel better about their mortality. The reality is you don't have to be stupid to get hurt.
Mike Jurnigan
Doug,
I have a question for you. I have the Performax 16-32. I don’t understand the statement that the in feed table was a little high. Were you trying to adjust the table that the feed belt runs on?
I am instructor for the Department of the Navy and I teach Lock Out/Tags-Plus to our people. One of the things that we require of our personnel is, on any equipment we service, that is not hard wired; must be unplugged before performing any servicing operation. I try to stress that it only takes a moment to unplug and that at most it is only a minor inconvenience. When you interrupt the flow of power (hazardous energy source) by unplugging there is no way that piece of equipment can inadvertently or unexpectedly start-up. I wish for your sake, you had unplugged before adjusting your machine.
With your permission, I would like to use your experience as a lessons learned in my course, so that others may benefit in the future and your suffering and pain will not be for naught.
Thanks,
Mike Jurnigan
Doug Reynolds
Mike: My guess is the resawing released tension in the three-plus inches thick Big Leaf maple causing it to bend ever so slightly so, when the trailing end came off the in-feed table it made a popping noise onto the conveyor belt/table. My thought was to lower the in-feed table just a little more as the Manual states the in-feed and out-feed tables should be just slightly lower than the conveyor belt/table to begin with. The sandpaper conveyor belt reached out and grabbed my thumb sucking it into the tiny gap between the in-feed table and conveyor belt table. When it got to the first joint and could not drag the thumb up anymore, it just sucked the skin off from the joint to the tip of the thumb. It's apparently called degloving. Got the stitches out today and, though it's ugly, all the original skin is still there and I should heal nicely. Hope to back to full duty and in the shop in two more weeks for a total of four weeks down time. I was truly lucky. I hope your students can learn from my mistake and, not have to learn from their own. It's a painful experience.
