OT faucet problem
OT faucet problem
OT faucet problem
james runchey
I replaced a lav faucet in a tenant apartment with a washer less unit, about two years ago as I was tired of replacing washers. Just got a call that the new one is now dripping . Is there any repair,or should I just replace? I suppose by the time I call in the plumber I'd be just as well off having him put in a new one.
Re: OT faucet problem
John E. in SC
Probably depends on the faucet. If it's a name-brand faucet, the rebuild kits / inserts are readily available and easy to install yourself. Certainly no need for a plumber. If it's a cheap no-name plastic unit sold for rental houses, might be best to replace the whole thing. If it started leaking after only 2 years, I certainly would replace with the same brand!
As you have discovered "washerless" means you won't have to replace washers, but you will have to replace O rings or whatever else they used in it. This might be a good reason to use name brand faucets because you can get the parts. If you know the make and model, get a rebuild kit.
Stuart Johnson
They might be washerless but have seals under the cartridge. Delta sent free rebuild parts (cartridge and seals) when I asked about them.
Make that "would NOT" replace with same brand!
John McGaw
Price-Pfister does the same thing. All I've ever had to do was to contact them and they sent out new rebuild kits for free -- when they say lifetime guarantee they appear to mean it. Actually, I've only ever had two small failures of one of their faucets (one of those seems to have been caused by 'crud' in the water) but it is good to know that if one fails it won't cost a fortune to fix.
james runchey
I looked at the faucet after posting, and it's rather odd in that it has no screws holding the handles on. Would these just pull off/ i can't see any other way to access them. Can't tell the brand faucet of faucet, should of kept the paperwork, I guess.
Del Williams
Is there a pry-off cover on the faucet handle that covers the screw?
james runchey
No, no pry off cover, the handles are one piece with no seams.
Inspect the handles carefully - many of the new models have set screws inserted from the side of the handle that tightens against the stem. These are hidden pretty well, and can be hard to find!
