ADVERTISE HERE - FREE TRIAL
High temp Adhesives ?
Keith Newton
Besides silicone, and resorcinol, are there any other instant adhesives that can retain their strength above 200* F?
Oh, and that will bond aluminum to wood?
Re: High temp Adhesives ?
Epoxy...but
I attended a seminar once given by an adhesives expert. He mentioned that some parts of airplane skins are epoxied on but that aluminum is tricky to bond. That's all I know about it. There are a lot of kinds of epoxy adhesives and I am sure some of them stay strong at 200F. It may be that bonding to aluminum will be as limiting in adhesive choice as the temperature.
Back in the day one could call the tech service department of 3M, and get an expert to recommend an adhesive. Didn't work the last time I tried it.
A quick Google search gave this  *LINK*
Locktite Epoxy Weld
Paul in NJ
I am sure there is an epoxy that will work, after all don't they bond the tiles on the Space Shuttle with it. Gougeon Bros who make West System epoxy have a two part etch kit for aluminum that allows you to bond it with epoxy. I have used it and it works fine. I don't think West epoxy is formulated for high temperature but if you contact their tech department I am sure they will steer yiu in the right direction.
Paul Dzioba
Possibly Dap Weldwood plastic resin *LINK*
Grant in Iowa
Here's a link to a .pdf for Dap Weldwood. It talks about a flash point greater than 200 degrees F, but I am not sure if that means it will hold at that temp. Suggest you call them and ask. I talked to a guy at DAP about 6 years ago and he gave me lots of good info for my application.
I can tell you it surpasses most common epoxies in terms of temp resistance. Of course there are many epoxies out there these days.
I find it is nice to work with, since you just mix with water.
FWIW,
Grant in Iowa
Dap Weldwood Plastic resin
Re: High temp Adhesives ? *LINK*
John McGaw
Finding an adhesive may be the least of your problems. Is the application going to be subject to moisture along with temperature changes? If so you will have an extreme differential expansion problem which will destroy any sort of rigid adhesive (or the wood?) no matter how good the original bond is. If it were possible, and I can't say since I don't know what your application is, I'd lean toward 'skyscraper tape' such as 3M VHB which is what sticks the massive glass panels to the steel framework in modern high-rise construction. Or more likely I'd avoid trying to stick two such dissimilar materials to each other in the first place.
VHB
Thanks All, I did a quick test with CA
Keith Newton
And I think it will work for need, at least it still seemed tough under theheatgun.
I only need a little spot, and can coarse sand the aluminum right before.
Keith Newton
I'm glad to learn about this product, but my load is all in shear, with only a small area to bond to.
TomD
I once glued on a golf head with epoxy, later the shaft broke. I had used one of those hot plates that keep you coffee warm (not that hot therefore) to heat the head while it was curing. To remove the head, I kept pouring on the heat with a blow torch, stopping every now and then to see if the head would come off. It go to the point where the head was glowing read hot and the epoxy finally flashed off like a Roman Candle. Of course no epoxy can take that kind of heat, but there was a ton of heat going in there, and it would not release. I`m it was 80% some heat sink aspect, and 20 percent the post cure I had done on the epoxy.
One thing to look for is a high glass transition temperature. WEST is relatively low at 160, It can even be a problem in the tropics if one uses off white paint. But most of these epoxies will perform a lot better if you raise the heat past the glass trans temp. For bows I have a hot box that is moderated with a hot water heater thermostat, so that it cuts out at 180F. That makes the bows OK in most hot trunk situations (not ok if they are left strung though).
Epoxy is not rated in many apps one might like to use it in houses, because he will fail early in a fire situation. It can be a great product to make expedient trusses out of, like to make a crane beam, or something. But you better be the person living there, so you know to run like heck if you ever have a fire.
Re: Thanks All, I did a quick test with CA
Pete in Holland MI
Try JB Weld.
Yep, that was going to be my second choice.
Keith Newton
But I was wanting a quicker set time. But then I found they make a kwick-weld now, which will for sure be my next choice, if I have to drop back to another option, but I'm pretty sure I have a working solution.
Hysol 9430
Robin Corell in Atascadero CA
Hysol 9340 is the best stuff I've found for bonding aluminum to something else.
Robin
JB weld high temp is good to 600 degrees. I didn't see a temp rating for any of the other epoxies listed. YOu can also get muffler repair kits but I don't know how strong the epoxy is. It will patch a muffler, trust me on that.
