Re: Got a tricycle and need
TomD
To be more specific. Are you taking about the drop, which is the part that the wheel assembly attaches to on the fork. Or are you taking about the anxle, or skewer using which clamps the wheel to the fork. Or some safety stuff that is a new add.
Normally the axles on cheap stuff are solid, the ends are threaded, and nuts hold the wheel assembly to the drops. Drops are widely available, but they are often just flattened tube segments also. Replacing drops normally requires welding, or brazing. You can use 1020 to fab drops.
