We're replacing a sliding patio door and I'm finding lots of mixed reviews on different brands. Thought I'd ask you all what brand you have installed and if you'd buy it again. We're looking at your standard size slider w/ screen. Looking to keep it under a grand, but don't want to go cheepo either.
While we do not have sliding doors here I do have experience with them and can recommend the Anderson brand.
For many years now my wife and I have been renting vacation homes in North Carolina's Outer Banks. In fact, we have already booked our week for later this year. We typically book oceanfront, which probably sees more than their share of sun, wind, sea air and mist, sand, and daily use throughout a year.
In all the homes we've rented, the ones with the best and longest lasting have been Anderson. In talking with a few homeowners and realty folks down there it seems that's the brand that stands up best in that harsh environment there.
Normally we rent a different house each year but several years ago we rented the same one two years in a row. The homeowner had a few Andersons the first year we were there and replaced the rest before the second year. The difference in how they worked was night and day over the Brand X doors they once had and the older ones were still working just as smooth.
I replaced mine a few years ago with a Pella triple pane. We have the blinds in between the panes of glass which makes it nice because we have cats and well cats are cats. It only take one finger to open it or close it. When the wind blows against it, unlike some doors it seals it tighter. The screen is on the inside so it doesn't get all messed up in the weather. It will close by itself or you can stop it with enough space so the cats can come and go as they please.
Jen, we have three Anderson sliding patio doors (vinyl exterior/wood interior) that are probably 20+ years old. One serves as the main entrance to our house. I couldn't begin to estimate how many times a day that door is opened to let the dogs and cats out, but it is still sliding just fine. And no damage to the vinyl exterior, however none of the doors are in the direct sun. They are very well sealed against rain and wind. We have had good luck with other Anderson products as well. I've also heard good things about Pella but they were harder to find at the time and quite a bit more expensive IIRC.
When we purchased ours, Home Depot gave a large discount if you were willing to wait until a regularly scheduled truck shipment delivered stuff. Don't know if they still do. Good luck.
Replaced the patio doors at the house with North Star products, found them at HD for about $799. They looked so good that several neighbours also did the same.
I have had Anderson, Pella and "economical priced" doors in my home. Home was built in 1880's - we have lived here about 50 years. All the maintenance and installations were completed by myself, friend and family. The first door we installed was an Anderson slider, it did hold up well for about 10 years and was used as one of the primary entrances while we raised 6 children. The Anderson finally failed due to leaky seals, bottom track and wheels wore out and windows clouded. Due to financial circumstances, we had to replace the Anderson with an inexpensive slider (around $400 35 ~40 years ago). The "cheap" door failed due to track, seals and glass seals failures in about 5 ~ 6 years. We then installed another inexpensive Borg door, this time with one fixed and one swinging door. Although this was far more desirable as far as weather tight but glass seals failed and wood deteriorated in a few years (4 ~ so we finally replaced the door with a Pella, again a swinging door and one fixed door. It was not cheap, as I remember about $1100 ~ $1200 about 10 years ago. It has an aluminum clad exterior and came with an unfinished wood (appears to be birch) interior. The hardware and locking system was/is excellent and the door still looks great. Although the door did not get the opening and closing the previous doors did due to the children leaving, it certainly looks like the seals and doors will hold up at least another 20 years. The only door I would purchase today is a Pella. Once I had installed a swinging door I would never go back to a slider either as the seals, wear on rollers and jams from ice and dirt is eliminated. The Pella is available as "dutch" style - both doors hinged or either of the 2 doors hinged. The locking system (bolt style at both top and bottom and at handle area) is extremely secure and seals great. The only wear apparent after over 10 years use is that the brass lever on the outside has tarnished and shows finish wear. I'm sure the price has raised to near $1500 but considering it appears it will last for at least 30 ~ 40 years it is the most economical door I have purchased.
I also like Pella. We replaced our cheapo slider 15 years ago. It still looks great and functions perfectly. I've looked at others causally since and would go back to Pella in an instant. Lowes carries them and if you get "standard sized" doors they are not too bad. Less expensive than Anderson around here.
I also would recommend the Andersen stuff.We had an Anderson slider on the rear of the house leading to the back yard that I replaced after about 25 yrs. Reason we replaced it was the sliding screen door needed to be replaced again. We had replaced, repaired, rescreened, adjusted, etc, etc, for the last time, through no fault of the door. Kids running into closed screen door, dogs running through closed door(St. Bernards), people flinging door open, people flinging door closed. I wanted a different design altogether. We put in an Anderson double french door style and love it. It has been in about 12 yrs now and I have not had to replace anything but the screen in the swinging screen door, again due to dogs. Seals are great, hardware is excellent. Opening both doors on a nice day is fantastic. Not cheap but really worth it.
Thanks everybody. I think we're leaning towards Pella after some research. Andersen is big here in INdiana but most of the comparisons and reports I've read put Pella up there above them consistantly.
