OK, head light beeper again.....
Had the ignition switch in my 2003 Honda CRV rebuilt. The beeper that reminds you to turn the headlights off (and the one for the key) went away. I am astounded at how attached I am to it. I have left the headlights on several times. Took it back to the shop and they fiddled with the wires and got it working, but made no promises. It had quit by the time I got home, about five miles. I took it apart and fiddled with the wires and got it working, for about a minute. Did it again and checked it over and over. Then drove it a couple of miles and its gone again.
So, if you unplug the "main" plug under the steering wheel the beeper works, Plug it back in and works again until you drive the car. Any suggestions?
Is there a "car guy" site that could help me?
Re: OK, head light beeper again.....
Sounds like a short, or a loose contact
Mark Nowicki
Do you have a "which door is open " indicator, and does that show the driver's door open when it is?
When the driver's door is open is the dome light on?
A wiring diagram would be handy.
http://www.eautorepair.net/Marketing/Default.asp
Mark
Weirdnesses.....
I usually leave the dome light in the OFF position. Just for grins I went and checked it out. Moved it to the middle or automatic position. The light does not come on when you open the driver's door, but it does when you open any of the other three doors. When you close the door, it fades out slowly (maybe twenty seconds). From the driver's seat, if you remove the key, (not when you insert it) the dome light comes on and then fades out after about twenty seconds.
The "door open" indicator does not work on the driver's door, but does work for the other three.
Also missing is the little glow light that used to indicate the key hole for the ignition switch.
When I fiddled with this and it went to work, I wiggled all the wires trying to get it to stop working, but it continued to function . I did not check out all the other lights, but I have forgotten what they used to do anyway.
The cowling on the bottom of the steering column has a metal plate in it. I suppose there could be a short. Maybe I will try removing it and leaving it off for a while to see if that works.
Re: OK, head light beeper again..... *LINK*
Bob Entwisle in NJ
Barry,
I googled "2003 CRV headlight chime not working"
And this is one of the links. An intermittent door switch sounds like a good bet to me.
That search turned up a lot of hits, I didn't look at them all but there are plenty of 'car guy' web sites out there and some pretty knowledgeable people on them including factory reps etc.
Hope this helps.
Bob in NJ
http://www.hondasuv.com/members/showthread.php?t=13732
Re: Sounds like a short, or a loose contact
Larry in NW Ohio
You might try www.cartalk.com they are the click and clack brothers that have a newspaper column in some newspapers. Their column is in our Friday paper, and they seen to know whats going on with cars. Good luck. Larry
Interesting.....
I wiggled the door switch and they went to work. Makes sense that the driver's side door switch would wear out. I seldom have a passenger and I bet that door has a hundred times as many cycles as the passenger side one and a thousand times the back doors.
This means I had three problems at the same time. The mechanical part of the ignition switch went bad, The door switch, and the starter. It sort of defies my simply logic to hunt for three things at once.
Thanks for the help. Wonder if I can just move a door switch up from the back or buy a new one? I'll Google changing the door switch.
Thanks for the heads up
I too have a '03 CR-V (and a '08 and just sold my '97). It's good to hear about potential issues, though so far, so good.
Re: Thanks for the heads up
I thought it was interesting that at least three things have gone wrong simultaneously, the starter, the ignition switch, and the button switch in the door jamb.
Keep it in your mind that the "wafer" type keys/locks apparently are prone to going bad. The locksmith fixed mine and then said, you will be back soon for the driver's side door and then the rest of them. Cost About $110 to rebuild the ignition which was rank, but much better than the dealer's $470 to replace it and another $105 to reprogram the new one.
So, if the ignition or locks start to get glitchy, check with a locksmith.
