Well, it's been raining so much, so hard, and so fast here that even the snakes are trying to find high ground. Last night, my driveway was under 18" of water and I walked within 2 feet of a water moccasin snake that was slowly moving towards the middle of the road because he and I both were looking for a place where flood waters weren't.
I finally got the framing drawing done of our existing house, new garage, and the 760 sq ft apartment that will be added onto our house. My MIL will be moving here at the end of May and I haven't even broken ground yet. Maybe, just maybe....I can get the batter boards up today and things figured out enough to get it all started by next week.
I came off of oncall duty this morning and I'm a happier man.
That's it for me, so what did YOU do this past weekend?
It's rare that I can start and finish a project in a weekend and, therefore, I usually don't qualify for this thread but I was able to finish these ash Easter Baskets.
Whenever we have dinners at our house, there are always way too many desserts left over (not to mention so much other food, too) and nobody wants to take it home with them, so it usually goes down the garbage disposer. My latest cocamamie plan, for Easter dinner, is to prepare these Easter Baskets with a few jelly beans, etc., and sneak in a serving of leftover dessert. A bit underhanded, I know, but but that's just the way I paddle.
I spent a few more hours clearing the log roads of downed trees. then on Sunday I went over to an old home-place and harvest a 24" - 20" x 10' long walnut log.
I had just sharpened my saw, so cutting it down and turning the top into firewood went pretty fast. But darn it, I had gone over without some of my loading tools, and didn't have any help. However, I have done this enough times to have some tricks that make the job easier and faster than you might expect. It only took about 2 hours total. Not bad for a 65 year old codger a bit out of shape from the broken ribs a little over a month ago. hum
To get a big log onto a flat trailer without the aid of a tractor, or any other power equipment, requires a little ingenuity. The first thing I do after dropping and cutting the log to length, is to cut a long wedge out of one of the larger limbs, then placing it near the expected balance point of the log.
To roll the log up the ramp, I use a chain wrapped so that inside most wrap tightens or chokes the log, then has another wrap which unwinds by pulling over the top of the log with my truck, as it rolls up the ramp. When it gets to the top, and onto another couple of feet of straight log, I can push one end down, then back the end of the trailer under the high end.
I keep several 2' long pieces of schedule 40 and 80 pvc in the truck for rollers which makes pulling it on up with a come-along easier. However, it can get hung on the back edge near the middle, so another trick, is to put another short log section under, about half way out to the end on the ground, then pull the truck forward. This and the first log wedge sections can act as rollers over the ground, while the PVC serves on the trailer.
They sell logging choke-chains, with a ring or a slip hook on the ends, but you can do it with just the normal hook. It seems a little confusing at first, if you have never done this, but I've learned a simple little trick that speed it up. Lets say we have a 24" D log, so we know the Cir is a little over 6'. So from the truck / wedge ramp side, lay out the chain, and fold 7' of it back alongside the longer part. Now grab it at the fold, and go over the log, and come under, then up to the top, where you can hook it with a slip type hook, or send the link type hook through, and back over, hooking back down a few links onto itself, forming a loop in the end of the chain. The long end then goes to the bumper hitch or toeing hooks on the front of the truck.
Had a really good time putting the finishing touches on my son's tool kit as part of his inheritance from his grandfather. Wrenches, pliers, drivers, electrical and plumbing tools, circ and recip-saws, sanders, drill press and drills, sockets and open end wrench sets in sae and metric, striking tools, levels and squares, plus a full set of lawn and garden tools and machines. The stuff hadn't been cared for so there was a lot of rust to get cleaned up. Went through a quart of phosphoric acid, and 30lbs. of #2 sand in the blaster. Then we cut and installed new back supports for his favorite chair.
Re: Another storm clean up, and harvested Wlanut..
Larry in NW Ohio
Keith, Pat yourself on the back, but just be careful not to break your arm. I sure miss doing that, I cut wood for 40 years, and really had fun do it. Larry
