Need computer part
Need computer part
Need computer part
Larry in NW Ohio
Have a 2010 Dell computer and the power source quit on me, and I am hopeing someone may have an old computer that would have a power source that was just laying around just waiting for me to maybe put it to work. The Model on it is ATX0350D5WA. So if someone would have one, I`d be interested in taking it off your hands, I don`t have any idea how much they are worth, so we would need to talk about thar. Thank You Larry
Re: Need computer part
Matthew Robinette
If you look on the power supply it should have the info to identify the specifics as to watts of output and it's form factor. Newegg or Tiger Direct should have one for under $30.
craigd
craigd
While that is a good idea, be sure and verify the connector (to the motherboard). The Dell's I have had were different from everybody else.
If I decrypt the model # correctly (ATX form factor 350 watts), you should be in luck as ATX is the common connector (although there are 24?(older) and 26 pin versions).
Piece Of Cake
Dustmaker Mike
check out Amazon they have severeal to choose from.
http://www.amazon.com/s/?ie=UTF8&keywords=atx0350d5wa&tag=mh0b-20&index=aps&hvadid=1316187182&ref=pd_sl_3m8ma8vp2m_pp
del schisler
i check ebay found a few http://www.ebay.com/sch/i.html?_trksid=p2055845.m570.l1313.TR0.TRC0.H0.Xpower+supply++ATX0350D5WA&_nkw=power+supply++ATX0350D5WA&_sacat=0&_from=R40
Larry in NW Ohio
I looked at ebay a little, it`s a possibility but was hoping to find one for free, but to pay postage. I only want the old one to toy with or maybe a backup, or something for the grandkids to play with. So I`m not in to much of a hurry. So if someone runs into one, please let me know. I would maybe pay 5-10 dollars for one in good shape. Thanks for repyling and keep a lookout for one for me. Thank you. Larry
TomD
I had a computer whose power supply broke down. I just wired up an any old one. It didn't even fit in the box. The computer eventually died, still have the supply for the next one that dies. I was buying desktops at 40 bucks a shot, so it really wouldn't pay to get a power supply that was all that expensive.
