Gurgle sound (OT)
Gurgle sound (OT)
Gurgle sound (OT)
Larry in NW Ohio
We had a couple of inches or more of rain last night and today and awhile ago I flushed the toilet and I heard a little gurgleing sound from the sink right beside the toilet and the clothes washer a little more down stream. Can anyone tell me what this is and is it a problem coming around the corner. Thanks to all Larry
Re: Gurgle sound (OT)
Keith Newton
There could be something stopping up the vent pipe coming down from the roof. Could be a bird or squirrel, coming down to check out possibilities, or a rat from below.
Dick Coers
Gurgling in plumbing means improper venting. Wonder if you had a birds nest in the vent stack that got soaked and is blocking it. Flashlight and a trip to the roof would see if it is clear.
Lee Schierer in McKean, PA
Gurgle sounds from drains occur when the vent pipe is not working properly. If this is just starting, something has happened in the vent stack above the level where the toilet and sink are located. If it has always occurred then the drain was not vented properly.
The purpose of the vent is to break the siphon suction effect of water going down the drain (toilet or sink) so you don't pull the water out of other traps in the system.
Lee
Jim Smith
Hello, When you go on the roof carry a water hose with you, if you don't see anything run hose down pipe and get someone to turn it on for you, usually all it takes to clear it out. Jim
If you have a septic tank
Bill Howatt
it might be time to get it pumped. When we start to hear the gurgle we know that tank servicing is very quickly going to be necessary. Of course, it may be more than just a pumping required.
In the more general sense, something is getting plugged be it from the vent end or the outlet end.
Bill
