Cleaning 16-32 belts
Marty
Good Morning Y'all. I read a few weeks ago how/what to soak sanding belts in. The love of my life,being a "clean freek"has cleaned up my dest,along with my notes. Any one recall? I think it was some type of paint remover???? Any help? Thanks Marty
Re: Cleaning 16-32 belts
Larry in NW Ohio
Marty I cleaned my woodmaster drum sander belts just last weekend after I finished sanding quite a bit of cherry,walnut and a few other boards. They were quite plugged. I have an old coffee container and filled it with about half and half of water and simple green. I roll the belt up in a roll and put it in the coffee container and let set for a half a day to a couple of days, depending when I think about it again, and lift it out and put a metal screen on top and then put the belt on top of that and let it drain for a day or two. Then I roll it out and blow it off with my compressor. It comes out fairly good. Larry
Don't have a 16/32 sander.
I have used "snot sticks" or sanding cleaning sticks on belt and disc sanders before - would they work?
Rick L
Re: Crepe rubber soles are the same  *LINK*
Rick L
as the abrasive cleaning sticks. Simple green is cheap and safe.
Abrasive belt cleaner
I use Simple Green also. I mix it fairly strong with water and soak the belts. A few hours or days if I forget and then put them in the sink and rinse them. Sometimes I scrub the stubborn ones with a brass bristle brush. I was sanding heart pine and the pitch in it would clog a belt in about three feet.
Some one else posted a link to Industrial Abrasives. If you are not already, you should look into buying the belts in long rolls and cutting them yourself. Just use one you have now as a pattern. Costs about a third of what precut belts sell for.
Not great experience with crepe stick cleaner
Jim in N. Va
Was making end grain cutting boards and running them through the Performax. Worked great, but had some slight burning. Looked like the sanding belts needed cleaning so I used the crepe sander cleaning stick. Belt looked like new! BUT, when I ran the board through again, I got some deep scratches. Near as I can figure, the crepe residue pick up some grit, stayed on the belt, and was then proud of the rest of the grit. That's what made the scratches. Took a LONG time with the ROS on the end grain to get those out. Never again.
Marty
Thank You one and all. Belt is now soaking in "Purple Simple Green" Who'd-A-Thunk,Green would be Purple?
Rick L
Only pitchy and resinous woods...
Rick L
Hardwoods do not clog up belts and there is nothing to clean.
Re: Only pitchy and resinous woods...
Jim in N. Va
Beg to differ. The cutting boards I was sanding were made out of hard maple, cherry, and black walnut. The sanding strips loaded up and causes some burning. That's why I attempted to clean them. But the cure was worse than the disease.
Another thought....
I know nothing about Purple Simple Green, but you will know shortly if it works.
I wanted to stress that sometimes cleaning won't do the job. If the belt is dull it still won't sand like a new one. Dull 80 grit is not the same as a 120 grit. Learn to tell when it is dull. Touch the belt and you will find that a sharp one feels very different than a dull one. The sharp one will grip (and sand) your skin, but your fingers will slide over a dull one.
You should use sand paper like some body gave it to you (or you stole It).
Rick L
Re: The glue...
Rick L
Been problem solving and repairing machines for 30 years. Hardwood doesn't need to be cleaned from belts but pitch, resin and GLUE clog belts. Using open or closed coated paper????
