Cock beading a curved edge
When I made the bow front chest of drawers I cock beaded the drawer edges. The procedure could be the same for the curved apron of a table. The following procedure is what I learned in the Mack Headley and Sons shop in Winchester, VA. (Have I mentioned that I learned a lot in this class?)
PIC 1
PIC2
The “reveal” is defined as the amount the cock bead sticks out from the face of what it is cock beading, in the case a drawer. A small piece of wood whose thickness equals this reveal is prepared as a gauge block. To begin I temporarily braded the 1/8” thick strip of cock bead material to the drawer edge. Then using this gauge block the reveal line was marked on the cock beading strip using a fine black gel pen.
PIC 3
The strip was removed and roughly band sawed close to the reveal line. The edge was then planed down to the reveal line. It could be spoke shaved but I found planing easier. I also found it easy to temporarily reinstall the strip on the drawer for planing and while planing I could check the reveal by eye. .
PIC 4
The cock bead scraper was made by cutting a semicircle into a piece of scraper stock with a chain saw file. It is essential that the cutting face of the scraper stock be polished or the cutting edge will not be sharp. I found it easier to pull the limber strip past the fixed scraper rather than the more customary pulling the scraper across fixed stock. There is no need to get this profile perfect. In fact there is something to be said for not getting it perfectly semicircular, everywhere.
PIC 5
The cock beading is installed with brads and glue.
