200+ woodworking book reviews
Gorilla Glue removal
ken chase
How do I get this off my skin? Tried acetone,kerosine
and more.
Thanks
Ken
Re: Gorilla Glue removal
An ounce of prevention
It can be easily removed with acetone before it crosslinks. Crosslinked polymers are insoluble in everything.
This stuff is sold as a polymer which when exposed to water or water vapor or moist hands, crosslinks.
Time or sandpaper!
I  promise . . .
steve mackay
. . . it'll wear off in a couple days . . . honest.
Re: I  promise . . .
William Duffield
It's always taken 5 days to wear off my skin, with or without biplanes. I finally learned to throw the bottle and the glue into the trash immediately upon its entry into my shop.
No matter what you are trying to bond, there is a better solution than Gorilla Glue.
del schisler
nothing breaks down the glue when it is dry, the next time use water right after it get on the skin, i belive it say's don't get on you, it turn's brown and will ware off. look kind of bad, i only use the white kind, it doesn't foam, the syurp looking does. both hold very good, but you have to keep scraping off the foam, one thing about the glue it doesn't cloug the belt's on the sander
That's why I don't like Gorilla glue. I haven't found anything it will do that either epoxy or PVA glue won't do as good or better and either one of them is easier to clean off your hands. I should say I don't use Polyeurethane glues and not pick on Gorilla glue itself.
My wife built a Volcano out of Hotstuff spray foam, which is basically just a different ratio of the stuff they make polyeurethane glues out of. When it started expanding it started collapsing so she used her hands to shape it while it hardened. We tried every solvent I could find and nothing cut it. It took her about 7 days to peel all the glue off and of course it took some hide as well. Naturally I took the time to show her on the can where it says don't get it on your hands. Probably the only time I was every right when questioning her.
Probably the only time I was right . . .
don stephan
. . . and you're still probably paying for it (lol).
William Duffield
A clarification: when I bash Gorilla Glue, it is the polyurethane type that I hate. Their white wood glue is similar to Titebond II, and I will use that, but only because I get a free bottle of it every January when I go to the Williamsburg woodworking conference.
It does have a learning curve, but
Mike31
I use Gorilla Glue (PU variety) all the time for a variety of tasks and in my opinion it out preforms any of the other glues I have used. It does have a learning curve and part of that curve is not to get it on your hands. Denatured Alcohol will take it off as long as you get to it right away. Once a few minutes have passed it's too late and you might as well just wipe it off with a paper towel and let the rest do it's color change thing. I find just a quick hard wipe with a towel right after getting it on my hands works very well, but then I'm only talking incidental contact with the glue, not dipping my hands in it or using my fingers to spread the glue.
It is not for everything but I use it for all my veneer work and 99% of my assembly work. Cleanup of the expanded foam is easy once it dries, don't try to wipe off the squeezeout. Instead be more careful with the quantity of glue applied so that only a minimal amount of squeezeout occurs. It doesn't take much GG.
Agree . . .
steve mackay
And it's a STEEP curve ! I wouldn't use it for MOST things. But it does have it's uses. And does those tasks rather well. I think the biggest problem is just forethought. You can't sling it around like carpenter's glue. And it darn sure ain't forgiving. But f you have your ducks in a row BEFORE you start your glue up, it's painless.
Mr woodwerkz
I usually wear gloves when I'm working with gorilla glue. If I do get it on me, I just grab a handful of dirt or sand outside my shop and rub it on to dry it a bit. Hell, your a woodworker, wear it with pride. Let the world know your doing something.
Will someone name an advantage or two.....
Except for outdoor wet exposure I haven't seen any advantage it has over traditional adhesives, especially cost.
Re: An ounce of prevention
Joseph Mulherin, sr
Best thing to wear when gluing anything is Nytril gloves. Then if you get the glue on your gloves just throw them in the trash. They are available almost at every outlet.
Re: Will someone name an advantage or two.....
steve mackay
This is probably my biggest type of use for it. The missile bodies are two pieces, laminated lengthwise. If I don't have the mateing surfaces exactly flat the glue expands to fill any voids inside. It also penetrates the wood farther than wood glue and gives me a stiff "spine" inside (and no twisting). Any gaps I might have on the outside are filled. And after varnishing the gaps that the glue filled are invisible. With wood glue (here in the desert) the bodies dry out and may split or separate down the seam. After I started using the Gorilla Glue I didn't have that problem. After many years of trial and error, it works. So I'll stick with it.
Re: Highly carcinogenic
TomD
Apparently they get away with their MSDS because it is not designed to go on the skin, but once it mixes with water/moisture on the skin it is bad stuff.
I get by these days with two sandwich gloves over my strong hand and one on my weak hand. rarely run into problems.
Gorilla expands to fill gaps, but the expanded foam form is very weak. I use it in certain situations, but overall avoid it. And mostly the it I use is Lepages.
I remember this old thread, that I picked as a quote off the WB forum:
(The Chemist)
The term "Polyurethane" glue means a lot of different things,
as you can see from the foregoing. that is because the guys
who write the hype for these products play fast and loose with
nomenclature and mostly don't know a carbonyl group from a
free radical, and would not recognize a urethane linkage if it
bit them on the nose. They work in Marketing. They keep their
consciences in a jar in the closet.
Very simply, glue is chains of atoms with some characteristic
structures along the length of it (the backbone, if you will)
and some other characteristic structure (a Functional group)
on the ends. After time exposed to the air, or after mixing
two components, Things Happen.
Maybe water vapor or oxygen in the air is the second
component, or something evaporates out of the glue, allowing
Things to Happen.
The result of Things Happening is that, after Everything Has
Happened, All those little molecular chains are stuck together
into one big molecule about a hundred miles long with more
branches and entanglements than the Interstate Highway System.
Bits of molecular hair are stuck out of the Big Molecular
Hairball everywhere, and they are more sticky than anything
you could imagine. They stick 'most anything they touch into
the Big Molecular Hairball and thus are all stuck to each
other.
Some glues are very rubbery, such as 3M 5200. Some are
relatively hard, such West System epoxy, Gorilla Glue or
resorcinol. The hardness has to do with the relative length of
the molecular chains this all started with, and how many
Functional Groups there are on each end and maybe branches
along the length. If there was only on each end one thing that
could connect to one other, you can see that we would grow
only longer molecular strands after Things Had Happened, and
our Big Molecular Hairball would have all the cohesiveness of
a plate of oiled spaghetti. The harder glues are made from
relatively short chains with many branches, so as to form a
rigid three-dimensional structure.
The Urethane reaction was discovered by Otto Bayer in 1938. It
consisted of a hydroxyl on one end of a molecule reacting with
an isocyanate on another end of another molecule to form a (I
cannot exactly draw it here, but one molecular chain has a
nitrogen with a hydrogen on it, the nitrogen further connected
to a carbon with a double-bonded oxygen connected to it, the
carbon further connected to an oxygen which was of the
original hydroxyl, that further connected to whatever the
original hydroxyl was connected to.) characteristic NHCOO
linkage in the middle of the chain. This is a urethane
linkage. A molecular chain may be made up of these
here-and-there in the backbone and yet be a conventional
varnish in all other respects, and some guy calls it a
urethane varnish. The boss says, wait a minute, I want a name
of my own. Call it Varathane. There ya go.
The urethane prepolymer chains may have silanol groups on the
end, as do most commercial caulks, and these react with each
other two or three times on each chain end, as well as
sticking to anything else they touch. Well, it does not cure
by the urethane reaction but it has some urethane in the
backbone so it is called a urethane glue.
Earl Scheib, famous for his "Yeah! I'll paint any car for
$99.95! And for an extra twenty dollars I'll even throw in
Polyurethane! [as the guy in the backgrouhd, dressed in a
chemist's lab, coat pours a clear glass cylinder of some clear
liquid into a can of paint] car painting television
commercials, had some other stuff. Polyurethane paint,
evidently.
The urethane glue may have no urethane in it but only
isocyanate-terminated molecular chains. Isocyanates react with
moisture in the air to form amines, with the liberation of a
molecule of carbon dioxide gas (aha!, you say...yes...but
wait...) and the resulting amine reacts with two other
isocyanates to form ureas (NHCONH, something like a urethane )
and the whole thing becomes the Big Molecular Hairball as
these Things Happen.
The Functional Groups have a lot to do with how sticky the
glues are. Isocyanate-terminated glues will react with the
moisture in the air and may, if there is enough isocyanate
present, show foaming when cured. No foaming is not proof of
no isocyanate, but suggestive.
Small isocyanate molecules are Bad Things To Breathe. Such is
in the Gorilla Glue, and maybe others, but I am not sure. Look
on the label in the fine print and see if it warns that it
contains isocyanates of any sort. You will need a magnifying
glass to find these warnings, usually.
I will try to find the Gorilla Glue diatribe and paste it in
here.
chemist
posted 03-07-2000 08:59 PM
Gorilla Glue is a mixture of monomeric and polymeric (meaning
three or four monomer molecules hooked together) methylene
diphenyl diisocyanate (MDI). The monomer content is a critical
health issue. The vapor pressure of the monomer is such that
if there is more than about twenty percent monomer in this
stuff, then it will exceed the safe exposure limit of fifty
parts per BILLION for MDI, which is considered a VERY strong
sensitizer. The ACGIH (American Council of Government and
Industrial Hygenists) does research and sets these limits. You
should believe them. The Gorilla glue MSDS and literature I
have seen says the stuff is safe and so forth, but that is in
the fully cured state only. They may not make this
distinction.
MDI will bond most woods well enough for some applications,
but should have tight joints. Isocyanates react with moisture
to liberate carbon dioxide gas and form polyureas when
reacting with themselves. The foamed polyurea may be weaker
than the wood. Exterior grade plywood is made by spreading a
thin film of MDI (The Gorilla just buys this stuff in drums
and repackages it) on the wood laminations and then the stack
goes into a press and that goes into an autoclave where it is
cured under pressure, heat, and live steam. So, for some
applications it is great stuff. Used in a controlled
industrial environment it yields an excellent product and the
stuff is cheap to make. Personally, I would never offer such a
product to the public because the permissible exposure level
(PEL) is too close to what a user gets when using the product
as recommended.
Go look at the label. Do they tell you to wear a gas mask with
an isocyanate-rated filter cartridge and not to get it on your
hands and what can happen if you do get it on your hands? Hah.
I'll tell you what happens when you do get it on your moist
little hands: The isocyanate reacts with the moisture to form
amines, and in the presence of excess moisture some amines are
left over that the other isocyanates do not find. The result
of that is that you now have on your hands methylene
dianiline, which is a really excellent and very efective
carcinogen. The safe exposure level for that stuff is "run
away at high speed".
Aside from those details, it can be a useful product. Wear
gloves and keep the wind at your back.
Tom, thanks for sharing that.
Keith Newton
I have never liked this stuff, and can't see any reason to switch to it. I'm not a chemist, and wouldn't pretend to take issue with anything he said, except the last sentence where he said.
"Aside from those details, it can be a useful product. Wear
gloves and keep the wind at your back."
As an old sailor and lifetime woodworker, I would suggest positioning the wind from your side. If the breeze is from your back, there is turbulence in your leeward side, so any fumes can be drawn back into this foil, and up your nose, unless of course, you happen to be a mouth breather. ha
Steve Schoene
But the expansion you get with GG in gaps just a foam with little strength. If you need to fill gaps with strength the only readily available glue is epoxy. And, GG creates a weaker bond in the standard hardwood to hardwood bonding test when compared to Titebond.
The only advantage I see is with certain woods or materials that don't bond well with Titebond or hide glue.
TomD
There is one application where I have used the foamy bit. Strip planking, usually boats. I learned this from another guy. You don't worry about having tight joints, they will be tight on the inside, where you live on big boats, then you let the glue foam, then you sand. Once everything is fair, the foam will have torn, and exposed bubbles of weak foam. Then you glass that side, and the epoxy fills in the holes, creating a hard wed that is filled with water displacing bubbles. It is a technique that works fast, gives a good finish on boats that are painted on the outside. Of course epoxy in the joint, or knuckle joints that leave little gap are better methods but sometimes time is of the essence, like when you need to beat the weather, or are working on a prototype. But yeah, it is the exception that proves the rule more than anything else.
Re: I  promise . . .
Sgian Dubh
"No matter what you are trying to bond, there is a better solution than Gorilla Glue.
William, as Bill Tindall mentioned in another post, polyurethane adhesives are well suited for wet wood applications such as building garden furniture and other external joinery. Typically, of course, these types of constructions are generally made out of wood that is either green or partially dried. For example, if we are building artefacts for exterior use they're frequently made out of European oak which, at best, has been air dried, and therefore seldom below about 18- 20% MC at its driest here in the UK. It's usually not the best choice to use kiln dried stuff for outdoor furniture, especially in North America where the target MC for this category of wood is roughly 7% MC, unless of course you're building for a very dry environment - I imagine, for example that places such as Death Valley and parts of Arizona might fall into this category.
The vast majority of wood adhesives are designed for dry wood bonding. By definition 'dry' means wood below 20% MC. So, polyurethane adhesives are the first I turn to for this type of work because it's effective, unlike PVA, epoxy resin, urea formaldehyde, etc types that I have seen fail so many times when chosen inappropriately by naive woodworkers.
All I'm saying I suppose is don't dismiss polyurethane glues out of hand: they are very effective in certain situations. Slainte.
that's good to know...
Henry W
That good to know. I had never considered moisture content and glue choices before, but I also haven't built outdoor furniture either.
Thanks.
Henry
There is little correct in the discussion
Who ever wrote the rambling discussion of urethane adhesives knew enough chemistry to sound like he might know something about what he was discussing. However, many details are incorrect and his conclusion is entirely incorrect. There is little useful information to be learned from it.
Isocyanate chemicals are used to crosslink the adhesive, or finish, which makes the material tough and/or hard. Many years ago small volatile isocyanate molecules were used for this purpose. The old moisture cured urethane varnish is an example. It was decided that these chemicals presented a health risk from the volatile vapor and they have disappeared from consumer products.
Similar chemistry is used in the modern urethane glue and finish except now the isocyanate part of the molecule tethered to the large nonvolatile polymer molecule. There is no volatile health risk.
However, isocyanate exposure can trigger an allergic responses after repeated exposure. For this reason it is best to not get it on the skin.
agree....
I used it to fasten a cleat to fix a broken stairs to the river. The wood was "salt treated pine" , the stairs are outdoors and they go under water from time to time. The urethane glue has held up fine.
Jason Roehl in Lafayette, IN
That depends...
My experience with GG is to NOT add water at any time. Just let the humidity in the air cure the glue. Additional water causes the curing reaction to proceed faster, and make more foam with larger bubbles (and potentially forcing a tight joint apart). Without adding water, the foaming action is still present, but greatly reduced, and I've found the glue is then quite tough. Of course, I live in Indiana, which is typically fairly humid, and I have not used it in the desert SW, so a different approach may be required there.
Do a test--put two separate drops of GG on a piece of wax paper, then add a couple drops of water to only one of the drops of GG (just drip them on top, don't mix). Come back a day later and see what you have.
Jason
End grain?
John in NM
I use it to glue a cap on the end of one kind of grip I make - gluing endgrain to face grain. I started using it because I had it and figured the way it cures would tend to work better with end grain than tightbond. I'll know in about 20 years if that were a mistake or not! :D
Once I use up the glue, I'm thinking I'll switch to West System epoxy or something similar.
I do usually wet the faces, but it's not required even out here. Changes the drying time from 8 hours to maybe 2-3 hours. Since I usually have these things tightly clamped, I'm not too worried about the size of the foam.
A friend of mine likes it for door joints too, or he did the last time I stopped in while he was making doors. If you can deal with the foam out, it seems like poly glue is less fussy to use than epoxy.
