Bowed Puzzle
Bowed Puzzle
Bowed Puzzle
Larry in NW Ohio
We have a puzzle that 2x4 feet and each piece is something like 4 x 5 inches and they all are bowed with the ends sticking up and that really makes it hard for anyone to put together let alone a very young person. I s there any way to get the ends to lye down flat so they fit together better. Thanks Larry
Re: Bowed Puzzle
Re: Bowed Puzzle
Assuming they are wood or plywood, if you have some pretty weather, you could lay them on the ground with the concave face down and the convex side up in the sun. The paving or earth wets (swells) the bottom side and the sun dries (shrinks) top. You could try the same thing on a slab floor. If they flatten, there is not telling if they will stay flat.
Re: Bowed Puzzle
Re: Bowed Puzzle
Howard Acheson
It sounds like you may have used minimally dried construction lumber. If so, and you lay the pieces down so air can only get to one side, the pieces will warp. You can try laying them down on to stickers which will keep the down surfaces above the surface below. This will allow the air to get to both sides freely. It may take a couple of months for the pieces to dry equally throughout the full thickness of the pieces.
Re: Bowed Puzzle
Re: Bowed Puzzle
Larry in NW Ohio
I`m sorry I was going to say that it is made of about 3/32 of an inch paper or something like cereal boxes with pictures pasted on the front. Larry
Re: Bowed Puzzle
try a flat iron
I have not tested this suggestion- disclaimer
Heat and some moisture will reflatten the pieces. Try a flat iron with a slightly damp cloth or paper between the iron and bent piece. Steam it flat then mash it flat until thoroughly dried. You want to make damp heat not tons of steam that could change the colors.
